I want to add surround sound speakers to my SAMSUNG DTV.
Now I have only just mastered turning it on and off so the instructions below are beyond my thick fingered capabilities.
Can I buy just any old surround system and just plug it in??? :eek
DIGITAL AUDIO OUT (OPTICAL)
xxWhen a digital audio system is connected to the DIGITAL AUDIO OUT (OPTICAL) jack, decrease the volume
of both the TV and the system.
xx 5.1 CH (channel) audio is available when the TV is connected to an external device supporting 5.1 CH.
xxWhen the receiver (home theatre) is set to on, you can hear sound output from the TV’s optical jack. When the
TV is receiving a DTV signal, the TV will send 5.1 CH sound to the home theatre receiver. When the source is
a digital component such as a DVD / Blu-ray player / cable box / STB (Set-Top-Box) satellite receiver and is
connected to the TV via HDMI, only 2 CH audio will be heard from the home theatre receiver. If you want to
hear 5.1 CH audio, connect the digital audio out jack from your DVD / Blu-ray player / cable box / STB satellite
receiver directly to an amplifier or home theatre.
I used to not give a foc, then I discovered Red Bull and now I don't give a flying foc !!!
Good advice from Alan, if you can understand it :lol
A few years ago now, I returned a Samsung amp to Richer Sounds as the fan in the back of it was well noisy (in my opinion not theirs funnily enough!) I took a Sony one home (fanless but a bigger box ) and it's still in use to this day.
Onkyo and Yamaha amps get good write ups usually.
You'll have to get yourself down to the shops and find an assistant who know's their stuff and can point you in the right direction of your price range.
Thanx guys. As I expected it looks far from simple. Maybe I will just go for some extra speakers such as..
http://www.amazon.co.uk/Logitech-980-000...ALXF25B04N
Those will be as bad as the speakers in the TV and not give you surround sound (just stereo out of the speakers instead of the TV).
What effect do you want?
Just a bit more sound really for watching action films etc.
Seems a shame to have all that high-tec wizardry and not use it.
I did try and connect the HD set top box to my hi-fi unit with some BNC? cables but no sound as yet.
Just had a thought :rolleyes does it not work as I am connecting a digital output to an analogue input???
Or am I being senior :o
PS. I spent a bit of cash on mine but if you want simple two front facing home speakers will do instead of surround sound and be easier to do unless you buy a surround package.
SITUATION UPDATE...............
After a bit of head scratching I thought I would try a 3.5mm jack to phono connection lead.
One end into the TV headphone socket, the other into my old analogue stereo amp.
RESULT!!!! Now have (virtual) surround sound on 4 speakers...............WOOT
I feel sure this shouldn't work as its a digital output into an analogue amp.
But it DOES so DILLIGAFF
