headlight upgrade
best cheapest headlight upgrade???
Upgraded Bulbs, wire both Lights on?
[Image: 151244.png]
Four Wheels Moves The Body... Two Wheels Moves The Soul
http://foc-u.co.uk/smf/index.php/topic,181.0.html
[Image: 151244.png]
The "x percent brighter" bulbs from Philips or Osram are quite good. I put a pair in the car and they are noticably brighter, chap next door with identical car  even said.
"Have you got HIDs in this"  :rollin
Downside is that they only last 300 hours (as against 1000 hours for a standard H1) and if you buy the very bright ones they will degrade your headlamp plastic cover (but my standard H1 did that anyway!) . Apparently they emit more ultra-violet than ordinary ones.
Having said that, headlight plastic in the year 2000 wasn't very good - just look at any W reg Ford Focus.
Buy branded ones ... there are a lot of well marketed chinese copies out there which are simply ordinary H1s/H4s painted blue.
On my 2000 FZS I did a complex re-wire with relay so that both lights are proper main-beams, but you don't want to go there .  :eek
I've got a 2002 "foxeye" with both lights taking the H4 60/55W bulbs. Cans I use any H4 bulbs, particularly the "up to 90% brighter" bulbs, or are there some to avoid?
Quote:Cans I use any H4 bulbs, particularly the "up to 90% brighter" bulbs, or are there some to avoid?
In a word ... Yes!
But you take your own risk , you should be aware that most of what's written about them is either "Marketing Speak" or "Paid Placements" from vested interests
(ie its mostly Bollox!). The truth is that they are simply H4s with better material control and a slightly more 'inert' gas filling that allows them to be driven harder.
I used "Osram Nightbreaker" H1s in the car and so far they are fine (2 years old).
They claim "All Osram Night Breaker bulbs are UV Protected and so are suitable for use on vehicles with plastic headlight lenses" .
They also claim that their new ones "Nightbreaker plus" have 50% more lifetime than the originals.
There are Philips equivalents but I would avoid other makes unless you can see evidence that they work as well.
Thanks, I'll stick to Phillips or Osram.
Cheers, J
go for hid kit spot on
from this [Image: 001.jpg]
to this  :b :b :b :b :b
[Image: 001-1.jpg]
Flee bay had HID kit for about £50
http://www.ebay.co.uk/itm/XENON-HID-Head...0294129095
I wired both lights for main beam and that seems ok and was simple
(08-10-11, 03:43 AM)Oxygen link Wrote:Flee bay had HID kit for about £50
got mine for 30 pound  car kit so got spare if thing go wrong h1 kit for low beam and h4-2 kit high and low for the high beam  :b
have them just over year and still fine  Wink
(08-10-11, 03:49 AM)Oxygen link Wrote:http://www.ebay.co.uk/itm/XENON-HID-Head...0294129095
How do you fit that HID H1 bulb?!
Got it, put the "balast", but can't figure a way to put the bulb and hohd it in place. Should I glue it or something? Sad
Has anyone had a go with LEDs?
Slaninar - the H1 bulb holder should hold it in but mine didn't either. In the end I used a pared down split wooden clothes peg to brace the holder between the clip and the holder.
My Fazer already had both headlights wired when I bought her so they're both on and it does look 100% better.
I bought some so called "uprated bulbs" and they were just dipped in some blue dye stuff? That's e.bay for you. Sad
(08-10-11, 06:08 PM)Slaninar link Wrote:[quote author=Oxygen link=topic=452.msg2480#msg2480 date=1318042147]
I have not done HID just wired both in. Sorry for confussion
H7 HID is the answer. It has a plastic "collar" that can be easily cut to fit just right in the Fazer's H1 original spot. The metal clip holds it in place. Will see about the brightness tonight, but even in daylight it looks a lot brighter than the H4 on hi beam. Should be nice.
So anyone looking for easy fit HID for FZS - go for H7 in place of H1 bulb - it works. Or hold on for a few more months to see how mine holds. Smile
(09-10-11, 03:57 PM)Slaninar link Wrote:H7 HID is the answer. It has a plastic "collar" that can be easily cut to fit just right in the Fazer's H1 original spot. The metal clip holds it in place. Will see about the brightness tonight, but even in daylight it looks a lot brighter than the H4 on hi beam. Should be nice.
done my with hid h1 kit hold it with 2 wall plugs :eek  one of both side and push the clip around it and it solid as a rock it been like that for half year know and still is fine :lol
(08-10-11, 07:23 PM)Kenny Dave link Wrote:Has anyone had a go with LEDs?
LEDs are good if lights have good optics (made for LED). Otherwise - not good. I have LEDs on rear and brake lights, but everything else is just not good. Tried it all - less visible and less light for me to see.
He did say "cheapest, best" ... so I guess a HID kit is the one.
If he'd said "cheapest, easiest" it would be upgraded bulbs.
Anyhow, I'm pissed off with being blinded at night so I've ordered one of  these for 22 of your Earth currency units..
http://www.ebay.co.uk/itm/6000K-HID-H4-3...27bc665306
I'll let you know how I get on.
