front forks
quick question , i have to fit some new front fork seals , what weight oil and air gap and best settings do you suggest ? cheers......
sorry forgot to say 2003 fzs 1000  Smile
Hi Scousy, just looked at my Haynes manual, if it can be trusted.
Any 5W fork oil ..........or Yamaha's own is apparently called '01' according to Haynes
2001 - 2002 European models have 440cc per leg
2003 - on models have 435cc per leg
The Fork oil level is 140mm measured from the top of the tube with the fork spring removed and the leg fully compressed.
NB - Euro Model Codes 2001 is 5LV1
                                2002 is 5LV8
                                2003 is 5LVF  so check yours first in case it's a 2002 registered on an 'o3 plate
IF IT AIN'T BROKE, FIX IT 'TILL IT IS.
cheers fella , just need to find the time to strip them change seals and refill now  :rolleyes
Bear in mind that the air gap is the priority, some slight variation in capacity is secondary..
