Andrew
Hi Andrew, I've linked the SMF site with the HP Wiki so that when anyone is logged in to SMF they will also be logged into the Wiki. It's not 100% perfect so I may have to undo it at some point.
Anyhow the relevant point is that when you click 'login' on the wiki page it will take you to the SMF login page and you should use your SMF password.
You are the only SMF member who already had a Wiki login so I do not know if there will be a problem for you - if so let me know Smile
[Image: 151860.png]
Alright, ta. There doesn't seem to be a problem, clicking log out through the wiki logs out the forum account too but it's no issue. I'll do some more of the wiki tomorrow and i'll let you know if it causes any issues.
