Long post
Heading
Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again. Some text copied and pasted over and over again.
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
Heading
As I was highlighting the headers it occasionally highlighted the heading and everything above. So if I'd have clicked B at that point then everything from the top would have been bold. So maybe it's kinda browser specific? I use Chrome for Dan and Opera for Farjo - Opera doesn't like the WYSIWYG thing at all and I have to switch it off, so maybe Safari has a problem with it too?
Let's see if you or anyone else has this happen again and try to work out the common elements Smile
[Image: 151860.png]
I'm using Firefox on here mainly, I only switch to Safari if Firefox spits it's dummy out.
Strangely Firefox has issues with the security log in for my internet banking and for my uni Pegasus stuff.
Frickin' thing.
:lol
Im using IE and having this problem
Plus font sizing when I copy over an article sometimes the font size changes.  Sad
Biking is about the Journey NOT the Destination...
Can you give me more details of how to reproduce this please as I'm stumped Sad
[Image: 151860.png]
In my stickies I have been transferring bits like this.
A. Found this on their site
Q. What’s the difference?
The two oils both have the same chemical make up although the High Temperature Oil is more viscous and therefore slightly thicker, meaning it will flow more slowly in higher temperatures than the traditional blue Scottoil.  Other than that, they’re the same and can even be mixed, so if you’re changing over from one oil to the other there’s no need to drain one out and start again, they’ll blend, saving you waste.
A. Which one do you need?
Your choice of oils is dependent on the general riding temperatures you usually experience.  Between 0–20 ºC (32-68 ºF) we would recommend Traditional Blue Scottoil.
John, looking at the SMF forum apparently it's an IE problem. But then they would say that :\
Anyway I've switched off WYSIWYG posting for your use, please let me know if there's any change.
[Image: 151860.png]
Yep thats better I can now see the font codes that were added.
Gone back and re-entered the articles.
Still got the Bold and Italic problem.
