Farjo - Naughty Corner membership makes you naughty...
Figured out why I had lost the ability to add things to the Gallery buddy, it was due to me joining the Naughty Corner group.
It was the only thing left I could think to try that I had changed, and lo and behold, that was it.
So, dunno why, but it seems that if you are a member of the Naughty Corner you aren't allowed to uplaod stuff, even to your own folders.
Cheers.
Andy
Thanks. The good thing about SMF is that it is so much more flexible in its configuration. The bad thing is that that means there's loads of settings and it is easy to set something up wrong :rolleyes
So it should work now, as NC members have the same rights to the gallery as normal members.
[Image: 151860.png]
Seems to work fine now bud, nice one! :thumbup
Whilst I'm annoying you with things, I found a wee issue with formatting on long posts.
I did the Ivanising one, and the formatting buttons up there ^ worked fine, but when I previewed the post it spat it's dummy out and formatted the whole thing past a certain point.
I'm assuming it was around the 2000 character limit?
Just meant I had to edit it again, putting in teh  boxes mesen, but mibbes worth checking up on?
Must admit though, this is already far more intuitive to use than the old 'un.
Big Grin
Well that explains why I couldn't upload to the gallery :pokefun
