Just loosen the rear axle bolts, but you may even be able to get it off without doing that to be fair. I managed it on my fire damaged one as at the time the rear wheel was stuck solid and the axle bolts weren't having any of it
I went to Loughborough Yamaha today to get the replacement front sprocket nut.
It was only 9mm so I didn't buy it. They insisted this is the current one but knew nothing of the saga.
Any ideas?
I would've told them to make a bloody effort to find out and do their job!
Give Fowlers of Bristol a ring and order it from them, they'll ask you for your chassis number so have it ready, it's on the frame at the front of the tank.
I haven't got the part number to hand but it's on this forum so do a search for the correct part number.
(26-04-13, 06:19 PM)elbrownos link Wrote: I went to Loughborough Yamaha today to get the replacement front sprocket nut.
Any ideas?
granbys said the same to me ,yamaha dont want to admit there is a problem
Yeah that's the jobbie, sorry i was using my phone earlier otherwise i would've searched for the part number, but do not accept any other number than 90891-10124
Loughborough yammaha fitted new nut and washer for me few months back . It was at my request and I supplied my own part which I got from wemoto. they didn't seem very clear on the issue and said it wasn't necessary , but did fit new one without too much complaint when asked and part provided.
Oh and if you have the google-fu I was eventually able to find a pdf copy of the yammaha service bulletin, technically it was for early fz6 models but same issue, had print out at ready but not needed in the end
27-04-13, 10:29 AM (This post was last modified: 27-04-13, 10:32 AM by Andy Clap.)
(23-08-12, 12:47 PM)YorkieFazer link Wrote: I contacted my local Yamaha dealer, CMC Clay Cross, Chesterfield and mentioned the inspection notice. They knew immediately about the problem and checked if my bike had been done, it hadn't, they ordered the parts and fitted them free of charge.
Can't fault the service that I have received from CMC.
I would advise anybody to contact their dealer and mention the inspection notice to service before buying the parts.
Ditto. My 2002 Fazer 600, not dealer serviced since 2004, CMC Clay Cross did it FOC with no quibbles at all. This was about September 2012. Even got a free coffee in the cafe while waiting!
can anyone tell a numpty like me wether i need to sort mine please ?
and yes, i know its mucky!
took the photo's before i cleaned the crud out!
[smg id=819 type=preview align=center caption="sprocket 1"][smg id=820 type=preview align=center caption="sprocket 2"][smg id=821 type=preview align=center caption="sprocket 3"][smg id=822 type=preview align=center caption="sprocket 4"]
(04-05-13, 08:29 PM)Enceladus link Wrote: can anyone tell a numpty like me wether i need to sort mine please ?
They *look* like the new type to me, but doesn't hurt to get a proper dealer to take a peek at it.
04-05-13, 09:15 PM (This post was last modified: 04-05-13, 09:18 PM by Foxwood.)
Doesn't matter really as the nut has held. Mine was visibly loose and only the locking washer was holding the sprocket on. I'd still recommend acquiring the new nut when changing the sprockets next time. Doesn't look like the nut is flush with the axle end as the new nut is, so could be that's still the old nut type. Only measuring the thickness would tell for sure. 9 mm -> old nut and 12 mm -> new nut.
(04-05-13, 09:15 PM)Foxwood link Wrote: Doesn't matter really as the nut has held. Mine was visibly loose and only the locking washer was holding the sprocket on. I'd still recommend acquiring the new nut when changing the sprockets next time. Doesn't look like the nut is flush with the axle end as the new nut is, so could be that's still the old nut type. Only measuring the thickness would tell for sure. 9 mm -> old nut and 12 mm -> new nut.
thanks
i'll keep an eye on it and change it next time i do the sprockets just to be safe.
04-05-13, 09:28 PM (This post was last modified: 04-05-13, 09:29 PM by Foxwood.)
(04-05-13, 09:18 PM)Enceladus link Wrote: thanks
No problem.
A good indicator that something might be going wrong is unordinary noise coming from the chains/sprockets that doesn't cease with lubing or tightening of the chains. At least that's how I caught onto my problem at first. Oh and found a few pics of the 2 different nuts to visualize them.
(04-05-13, 09:28 PM)Foxwood link Wrote: [quote author=Enceladus link=topic=3710.msg73750#msg73750 date=1367698738]
thanks
No problem.
Edit: Left one is old and right one is new.
many thanks
