Sorry to be a dimwit. How does the gear indicator work ? or is it just a neutral indicator ?
i don't like the ones that work off speedo / rpm personally. seems like guesswork.
Cheers, DBo.
The gear indicator is indeed speed/rpm and seems to work very well, clutch in it doesn't know but as soon as it's out it's spot on.
My gps module(VK16HX @ £7 inc postage) arrived today, fitted in the clock housing well and setup dead easily, won't be able to play anymore for 2 weeks as going on holiday.
Have you got any pics fitted? What does the gps function give you, does it just give your latitude and longitude? Mine arrived today so I'm hoping to fit it next week.
Andy
It works based on speedo/rpm. And yes, it's guesswork. But it works very fine as long as you do not pull the clutch.
The speedo/rpm ratio is specific for each gear. The gauge compares this ratio to a stored table of scenarios and estimates the current gear. Once a gear is recognized and looks stable it locks to this gear. A lot of computing is done in the background to get a stable reading and filter false recognitions. I've optimized the algorithms over several years and always with focus on the Fazer. I guess it's fair to say that you won't find a gear indicator that works more perfect on this bike.
By nature this principle it not able to give proper readings at standstill or slipping clutch. But as long as the clutch is engaged it works perfect.
Besides, it offers much more functions than a simple gear indicator ..
Price like that has me tempted with the GPS addon. Might as well get full use from the device
was it this one Haddock?
http://www.ebay.co.uk/itm/V-KEL-VK16HX-G...4180fd37f8
On another note, I was thinking about changing bulbs in the clocks to blue LED's. Can I also change the illumination on the multigauge to match?
thanks,
Lord,
Grant me the WD-40 to move those things that are stuck, the Duck tape to fasten those things that are loose, And the wisdom to know the difference.
Amen
The GPS function was primarily intended to provide altitude readings. But there are screens available showing almost all data coming from a GPS module.
The given module looks suitable. Though I'm unsure about the TTL voltage level. Guess the VCC_N line defines this. If this is tied to 3V it should work. Didn't find a datasheet so far.
The backlight of the LCD is fixed. You can change it if you have the proper tools but it would have been much more easy before assembly.. Anyway, I could guide you how to do it.
That is the gps I have fuzzbomb, powered from the cl8 point shown in the documents provided and seems good, I've only powered it briefly but seems good.
17-07-14, 02:12 PM
(This post was last modified: 19-07-14, 05:12 PM by kevinuk1.)
I have one of these for the FZS 600 from Christian have decided not to fit its brand new only just received from, anyone want it can have for £115 inc postage
Thanks
AKA - Jase / Carbonkid...
Hi guys,
I hope everyone is getting on well with their multigauge's..
I was but seem to have hit a snag today... well Kinda my own fault. I ran out of fuel lol.
When leant over on the side stand shows as 0 Liters. when You pull it up straight showed 3 liters.I thought I would be ok so went on my short run to work. half way there (about 3 miles) it conked out.. opened fuel cap, dry as a bone.
Any way to calibrate it or should I take as my own fault and pay more attention to the fuel light? lol
Lord,
Amen
Hi schlumpf,
ok I might take a look at these settings and have a play. Also while I think about it I have never seen the gauge read more than 20 liters when the tank is full. I thought the FZS1000 tank was 21? (according to online stats)
could reducing this value also show my full capacity as 21 liters?
thanks,
Fuzz
Lord,
Amen
On paper and by geometrie it might be 21 liter but you will never managed to put more than 20 liter in. There is an residual air buffer preventing to use the last liter. That's why I restricted the readout to 20 liter. But feel free to alter the upper limit in the menu (like it's done for the 600s).
I'll create a guide and let you know. Give me some days.
Quote:be careful to now over-torque
'Now over-torque' is a lot different from 'Not over-torque' Cristian :lol
It's fairly obvious what you mean but every idiot proofing brings along a better grade of idiot ready to blame someone else for their own stupidity.
