28-01-13, 01:32 PM
I've done the full set of warning lights too, but I'm considering changing the full beam light back though. The new bulb is just too bright and distracting, at a time when you want to see the road better.
what u think guys n gals
28-01-13, 01:32 PM
28-01-13, 02:23 PM
It is a bit glarish i agree but the green fuel light is ok. Provided uv not got full beam on its ok. I use an ultimate addons iphone case/clamp and when i indicate or watever and the light come on the case stops the glare.
Just flapping about on this stagnant little pond on the outer rim of the internet.....yup.... :-))
28-01-13, 08:13 PM
Hi I would prefer to get the slightly dimmer blue bulbs so I can read the lcd so how do you know which brightness you will get bwhen you order them do you have an ebay number for the bulbs you got thanks
28-01-13, 08:53 PM
any t5 286 1.2w will be ok. the brightness u will get will be the same but remember blue is harder to see than white so there always gonna be less bright. the stems that the led is built around is longer so less light permeates round the speedo display and as they r closer to the turn signal/main beam plastic covers they will glare.
28-01-13, 09:34 PM
Anyone done this in red yet
02-02-13, 03:33 PM
Seeing as my bike is Red, and there aren't any pictures up yet; I'll order some LEDS in, and change mine to red. I'll post some pictures up when I'm done to see how it is!
03-02-13, 11:05 PM
Hey everyone, Just done this mod today with blue LED's as i've got a blue foxeye 600. Very easy, Looks great, and took me about 45 minutes as I spent half the time cleaning the fairing brackets and typically I had put all the bulbs in the wrong way around.. hahaha. Always hated the standard lights for the dials. I won't bother with a picture as you all know what it looks like
![]() A huge thanks to dead eye for the very helpful pictures and descriptions on what to do. I removed the screen and have no idea why you wouldn't to do this mod as it makes access to the nuts so much easier. I also replaced the nuts and washers with stainless ones as they were a bit corroded. Was a good chance to get all the fairing brackets cleaned up too ![]()
04-02-13, 07:33 PM
Did mine took 10 mins looks great can clearly see my lcd I bought 10 for £3.49 off ebay item number 230794749323 if it helps.
07-02-13, 11:47 PM
Did the mod today all went fine went to use my bike and the rev counter has stoped working. The needle has gone right round to far to the bottom. Looks like the clocks have to come off again
Ride it like you stole it!!
22-04-13, 10:17 PM
I bought some SMDs but with the ones I got, each bulb had three sides and so the light spread more evenly across the dials. Bought white ones and they're much brighter.
22-04-13, 10:41 PM
http://www.ebay.co.uk/itm/T5-286-3-SMD-L...4ac3328968
something like this should do the trick. I put "T5 smd" into ebay and a few of them came up.
23-04-13, 02:44 PM
Is it just me, or is the life expectancy on these bulbs crap?
I changed mine to white single bulb ones, and all three died within a couple of months. Changed to some 3-bulb ones, and one has already given up the ghost after 2 weeks. I wouldn't mind so much if they were quicker to change.
23-04-13, 04:06 PM
Haven't had an issue with any dying on me but I'm rather thankful for how easy they are to change. On my old Mk2 Golf you had to disassemble the entire dashboard just to try and even get the clocks out. You would then spend the next 6 hours trying to reattach the tacho and speed sensors to the back of the clocks whilst attempting to get them to sit in the right bloody place...
11-05-13, 12:09 AM
Ah, you went with the white ones in the end, looking good :thumbup
07-11-13, 08:31 PM
fitted two in my head light
now 200% more vision at night
if it dont got an engine it aint a sport
07-11-13, 09:32 PM
(07-11-13, 08:31 PM)codgie link Wrote: fitted two in my head light You need one of these.......
07-11-13, 10:20 PM
Even this would be better :rollin
[img alt=http://ak5.picdn.net/shutterstock/videos/4737701/preview/stock-footage-elderly-man-lighting-an-old-oil-lamp-in-darkness.jpg]http://ak5.picdn.net/shutterstock/videos/4737701/preview/stock-footage-elderly-man-lighting-an-old-oil-lamp-in-darkness.jpg[/img]
23-01-14, 10:11 PM
23-01-14, 10:36 PM
Yeh ---- right then
I dont know who it was on here but a few weeks ago they posted look at my blue clocks and then not long after each bulb blew Just sayin May look good on a blue bike but I want some black ones to match my black bike ! Maybe I just fit the blue and wait a few days
24-01-14, 10:07 PM
In a previous project I converted all dash lights on a Mazda MX5 and I had issues with leds blowing from the cheaper versions on ebay. After a bit or trial and error I have found the seller Goodwill sales supplies the best quality leds.
I have fitted red, blue, green and yellow in various cars over the years ![]() |
« Next Oldest | Next Newest »
