09-11-12, 09:57 PM
got mine sorted, turns out it was 2 faulty spark plug caps so no need for a video
hope you get as much luck as me and thanks for the replies haha :b
stuttering fzs 600
09-11-12, 09:57 PM
got mine sorted, turns out it was 2 faulty spark plug caps so no need for a video hope you get as much luck as me and thanks for the replies haha :b
10-11-12, 01:57 PM
(08-11-12, 10:24 AM)red98 link Wrote: [quote author=cnw180 link=topic=2066.msg45433#msg45433 date=1352329384] ummmmmm .....not sure about that ......start by swaping the filter...i dont think thats the problem but once swaped you can forget about it .....balancing the carbs is always a good thing do you know when it was last done ? [/quote] .....well, checked the plugs and ht leads, bit of wd40 applied. Left New air filter in place as I noticed the rubber cover over the airfilter casing had snagged over the air intake, possibly restricting the airflow. Assuming the engine needs a huge "gulp" of air when the throttle opens, this may have been an issue. Will test ride before putting old filter back in. Bike fired up fine, needed a bit of choke, normally doesnt! Idling ok, just a tiny bit lumpy... Will post back later!!
10-11-12, 03:00 PM
@cnw180, I had a complete carb overhaul done at PDQ, cleaned, balanced, etc, but when i went back there about 18 months later with a rough running problem between 2-300 revs they balanced the carbs again and said that they were quite a lot out.
I really noticed a difference when riding home, so i'd imagine that if you haven't had yours balanced in over 3 years that could be a place to start first!
10-11-12, 03:32 PM
fixed me stutter!!
...very weak spark on number 3 plug?...so trimmed leads and replaced caps plus swapped plugs as i had a new set in stock!! and runs perfect again. ....what i did notice though was when i released the tank filler cap" there was a lot of suction on the cap?...chkd out the tank breather and it was blocked :rolleyes ...now cleared!!...
10-11-12, 03:41 PM
Did i just read that correctly ??? :eek :eek :eek
10-11-12, 03:43 PM
10-11-12, 04:06 PM
Sorry, my fault, i'm so used to seeing your name on this post i thought you were red98 :lol
I thought it sounded a bit casual........ :lol
10-11-12, 04:09 PM
10-11-12, 05:12 PM
This is like waiting for the next season of your favourite TV show to start... come on red, I want the next episode already
![]() After 8 months this has been like a master class for the air / fuel system in the Fazer
10-11-12, 09:17 PM
evening all
.......swmbo`s car in garage at moment and in true RED style its in bits :o got a water leak between thermostst housing and cylinder head,golf 1.4,nobody stocks the rubber o ring seal so got one from local bearing trader will put it back together tomorrow CRH....cheeky bstd.....iam the best looking bloke on here darrsi....iam looking forward to the day when i can post something along those lines....i`ll be dancing in the street :rollin :rollin :rollin starting monday, working every day for the next 12 days then i have the weekend off which will be time spent with the stutter
think darrsi might be right you know red ?.....you could easily become the next author of the..second,new,testament of the fazer bible :rolleyes ...ile buy a copy off you? :b .....ps did you read i fixed me stut??
11-11-12, 03:26 AM
@red98, have you thought of contacting Gareth Gates, he had a bad stutter but seems to have sorted his out okay :lol
(10-11-12, 01:57 PM)cnw180 link Wrote: [quote author=red98 link=topic=2066.msg45450#msg45450 date=1352366676] ummmmmm .....not sure about that ......start by swaping the filter...i dont think thats the problem but once swaped you can forget about it .....balancing the carbs is always a good thing do you know when it was last done ? [/quote] .....well, checked the plugs and ht leads, bit of wd40 applied. Left New air filter in place as I noticed the rubber cover over the airfilter casing had snagged over the air intake, possibly restricting the airflow. Assuming the engine needs a huge "gulp" of air when the throttle opens, this may have been an issue. Will test ride before putting old filter back in. Bike fired up fine, needed a bit of choke, normally doesnt! Idling ok, just a tiny bit lumpy... Will post back later!! [/quote] Well I put the original filter back in and the bike is now fine, stutter gone! :lol Checked the two filters while out and the new one is a tiny bit smaller. Noticed the box it cam in had 98/99 for the year. Wonder in the filter is different on the 2000 model then???? Anyway, bike running nicely, carbs do need checking for balance, but power all back now!!
11-11-12, 05:21 PM
Was the new filter a Hi-Flo one by any chance?
11-11-12, 05:33 PM
11-11-12, 06:15 PM
I had one like that, and i think it was also red98 too, and i never really thought too much about it until i swapped it for the K&N filter about how ill fitting it was.
The K&N made a really tight, fitted seal whereas the other one probably had about 5mm play around it. I doubt very much at all that it's anything to do with the year of the bike. I would seriously recommend getting a K&N filter though, you can really notice the bike breathing better, and you only need to buy the one as they're guaranteed for a million miles, and you don't even need to clean it for the first 50,000 miles! £30 on Ebay.
11-11-12, 06:49 PM
(11-11-12, 06:15 PM)darrsi link Wrote: I had one like that, and i think it was also red98 too, and i never really thought too much about it until i swapped it for the K&N filter about how ill fitting it was. Sounds like a plan!
11-11-12, 08:10 PM
(11-11-12, 06:15 PM)darrsi link Wrote: I had one like that, and i think it was also red98 too, and i never really thought too much about it until i swapped it for the K&N filter about how ill fitting it was. yes thats right darrsi....lousy fit but did`nt notice untill i fitter the k+n......well worth the £30...best filter by miles
11-11-12, 08:15 PM
ummmmmmmmmmm gareth gates.......................now iam sure you dont want me to start singing :eek :eek :eek :eek :eek that will be worse than the stutter :rollin :rollin :rollin :rollin :rollin :rollin
well swmbo`s car back together and working but will need a new thermostat housing :\ :\ :\ just needs the o ring seal but cant buy them on their own :\ always something to spend your money on
11-11-12, 08:19 PM
I really should apply for a job in the K&N marketing department........ :lol
« Next Oldest | Next Newest »
