Took the suspension link off to give it a good clean and lube the needle rollers. Fitted a carbon fender extender. Looks absolutely crap :'( , but no doubt the radiator and header pipes will appreciate the addition.
(21-04-20, 04:23 PM)robbo link Wrote: Took the suspension link off to give it a good clean and lube the needle rollers. Fitted a carbon fender extender. Looks absolutely crap :'( , but no doubt the radiator and header pipes will appreciate the addition.
Haha I've looked at them but admittedly didnt like the look although it would be the kind of thing I'd fit for the winter to save the pipes a salt bashing and then take off again in the summer
Did you at least get a black one so it's slightly more inconspicuous?
Washed and polished the 600
Re:the fender extender. Couldn't find a gloss black one, so went for proper carbon which sort of matches the mudguard and the engine finish. Only if you've got your eyes shut though :lol . Maybe I'll look out for another mudguard to fit it to for trips away, which is when it's really needed, as they look absolute dogshite. Only siliconed it on, as drilling holes was for too drastic.
All washed, polished and nowhere to go :'(
(22-04-20, 04:48 PM)unfazed link Wrote: All washed, polished and nowhere to go :'(
I like the way the red bush behind complements the bikes
Yr thou is identical to mine  the best colour scheme in my opinion, others will no doubt disagree ???
(22-04-20, 05:23 PM)fatbloke62 link Wrote: Yr thou is identical to mine  the best colour scheme in my opinion, others will no doubt disagree ???
Agree and I'm not even biased  :lol
My 600 baby turned over 92800miles today returning from the shop, have it since new when it had 1 mile on it  Smile
(22-04-20, 05:30 PM)unfazed link Wrote: [quote author=fatbloke62 link=topic=6412.msg313128#msg313128 date=1587572609]
WOW !! That's dedication. 8)
I'm quite partial to this version
[Image: 49813169902_db608d24d2_o.jpg]
[Image: 49812867321_a5ebaae36a_o.jpg]
Later
Been trying to find more things to play with on the bike so thought today I'd have a go at vinyl wrapping. Just did the two boys of underseat fairing as a start.
Looks alright, my bikes first bit of faux carbon ?
Did you use the wet method or the dry method with a heat gun? Looks good  :thumbup
(25-04-20, 06:52 PM)Fazian link Wrote: Did you use the wet method or the dry method with a heat gun? Looks good  :thumbup
Dry with a heat gun... and thanks ?
Tried to get the old brake pipes off to install new ones...!
Firstly I had problems with fastenings and screws that hadn't been undone for ages (or, even, since the bike was new!)
The Haynes manual says you need to drain the old brake fluid, but doesn't say *HOW* so I tried opening the bleed valve and putting a tube into a bottle whilst pumping the brake lever.
That worked for a while, but then stopped. So I thought I'd open the top of the front brake reservoir, but one of the philips head screws that holds the cap on rounded out, so after about an hour of trying penetrating oil and freeze spray etc, I eventually had to use the Dremel to cut a slot in it (and also in part of the cover too Sad )
Then I undid the banjo bolt on the FBMR which let a little more trickle out, but not much.
I left that for a while and decided to try to undo the screw connectors that go to the hard lines from the ABS modulator, but, they wouldn't shift, to get better access, I ended up taking off the fairings and headlights (needed to do that any way for other stuff), however, even with better access, they still wouldn't move.
So I've squirted in a load of penetrating oil (and on a whole bunch of other fastenings) and I'm going to leave it overnight and get back to it tomorrow... Sad
Regarding the brake reservoir screws, were you using a proper JIS screwdriver(Japanese Industrial Standard). A regular Phillips won't "bite" into the screwhead properly as the blade angles are wrong, resulting in the head getting chewed up. Smile
Do you have access to a vacuum brake bleeder, it is as you have found out a pain trying to do it without one.
Gravity flow to let the fluid drain out works well in a non ABS setup but not as well on ABS setups.
Other option is use a large syringe to pull the fluid through and out of the system and to pull it through to refill it.
Do not  turn the ignition on while you are doing this.
When finished and the brakes work again take the bike out and get the ABS to kick in a few time to allow it cycle the fluid through the ABS unit.
If after the ABS kicks in the brakes feel soft bleed the brakes again.
I changed the screws on the Master Cylinder Cap, see Picture
Attached Files Image(s)
(26-04-20, 10:27 AM)robbo link Wrote: Regarding the brake reservoir screws, were you using a proper JIS screwdriver(Japanese Industrial Standard). A regular Phillips won't "bite" into the screwhead properly as the blade angles are wrong, resulting in the head getting chewed up. Smile
Damn, I didn't even know that *was* a thing...!  Sad
It might be that sort of screw, then.
I've just had a look online and most of the ones I've found are listed as out of stock, but there's these JIS Impact Screwdriver bits which might be good as they'd deal better with stuck screws too.
Thanks for the info :thumbup
(26-04-20, 10:43 AM)unfazed link Wrote: Do you have access to a vacuum brake bleeder, it is as you have found out a pain trying to do it without one.
Nope, nor a syringe Sad
What I've had to do was literally just undo each connector with kitchen roll ready to catch any spillage, then let it drain into a bottle before doing the next one. (Oh and then wrap the banjo bolt in a ziplock plastic bag and wrap an elastic band around it in case there's any fluid not yet drained!)
I'm still having problems with the screw connectors, I've been spraying them all day with penetrating oil and I'll give then another try in a day or two.
If that doesn't work, I'm going to pack tin foil behind them and try with a heat gun.
There's a test routine on the FZ6 which is designed to pump the fluid through the ABS system, hopefully after that and a bleed it'll be ok.
Quote:I changed the screws on the Master Cylinder Cap, see Picture
I might do that if I can't get any JIS screwdrivers :thumbup
So this is how far I've got.
Windscreen, fairings, headlights all off, to give better access to brake hose fittings, but also because I need to do a permanent fix on the LCD display that started flickering and fading some time back. I bodged a repair that worked for a while (see another thread somewhere), but it's going duff again, so I need to sort it properly.
Also I'm going to get rid of the old fork springs and replace them some Wirth ones instead, plus, of course, new fork oil and maybe seals too. At the same time I'm going to repaint the forks because they're a bit battered.
Rear brake off and rear wheel out. I'm going to service the calipers properly, clean them up, new seals etc whilst I do the brake lines.
Swing arm dropped a) because I'm going to put a YSS rear shock to replace the knackered (and crap!) OEM one and b) because there's a stupid cover plate in the middle of the bike (buried under a whole load of other stuff!) that needs to come out so I can get access to the ABS Modulator and the hoses that come off that, but the only way to do it is to remove the rear shock and exhaust mid-pipe! (Another wonderfully stupid bit of design by Yamaha...  :rolleyes )
Still, I needed to take the exhaust off anyway, because I'm going to regrease the swingarm bearings and the underseat pipes on the FZ6 go up *through* the swingarm and you can't get access to them without doing that.
I just have to hope I can remember which order I need to put it all back together again...  :eek
Had a quick look for JIS screwdrivers. The cheapest set of 4 made by Sealey (AK4314 JIS) that I could find, and are very similar to my Laser set(Laser Tools 7036), are £13.93, ebay item code 184084743936.
Users browsing this thread: 35 Guest(s)
