(31-07-18, 09:20 PM)AJM link Wrote: Went for a spin this evening and found this  Smile
Cor! deary me  I don't know, some people, right litter bugs ehh! fancy dumping that old Fazer there.  :lol
(05-08-18, 11:05 PM)tommyardin link Wrote: [quote author=AJM link=topic=17296.msg282573#msg282573 date=1533068405]
[/quote] :rollin :rollin
(05-08-18, 09:55 PM)TOM VR46 link Wrote: First post , so see how it goes. Went for short spin after MotoGP to get some new chain lube and decided to get Chain Wax. Never tried this before. Anyone know how good or bad it is.
I use it. Have a search on here for chain lube, wax and you will find loads of past posts discussing all manner lubes for the chain. I use  Puoline Chain Tech. Heres a good one for you http://foc-u.co.uk/index.php/topic,20030.50.html
I've been getting achey hands on the Fazer which have gotten worse over time and I keep catching myself leaning on them, so on some advice I got a set of bar risers to try out:
[smg id=3189]
[smg id=3190]
Bars are currently spaced 20mm away, the kit includes extra 5mm and 10mm spacers to move them even further if necessary, but this is already pushing the brake hose a bit, so I'll have to get a longer one made if I stick with them. Rest of the cables have plenty of slack, and the bar mounts being angled means it doesn't hit the fairing at full lock Smile
That gap is bothering me though... I'll have to get a deeper clamp top and skim it to fit!
Ive used Wurth chain wax for years. Great stuff, not messy and keeps the chain in good order.
Then again, I do have a chain cleaning OCD  :lol
Well used chain wax and after a week , with a couple of wet runs, result. Roughly about 250miles and definetly a lot less mess than lube and still a good covering of wax on the chain.  Smile
Well not today but yesterday, I adjusted the chain and gave the rear caliper, pots an pads a good clean. I should have done the fronts too and adjusted the clutch while as was at it. It'll need to wait till next weekend now.
Went naked,
:useless
Overhauled rear caliper with a stainless kit. Time to open the bleed nipples and let gravity do the work while I get my tea.  :b
naked Fazer
Took mine out for 1st time, returned home and straightened the warped rear disc.
(24-08-18, 10:24 PM)deeteefifty link Wrote: Took mine out for 1st time, returned home and straightened the warped rear disc.
What’s your technique for straightening the disc?
This. Found the high spot and gave it a tweak.
(25-08-18, 08:46 AM)deeteefifty link Wrote: This. Found the high spot and gave it a tweak.
Little word of advice........don't do that.
One, it's just wrong, two, i've never heard of a warped rear disc, EVER, and three, don't do that ever again.....please.
You aren't 'fixing' anything by bending a disc. If it needs changing, then simply change it.
I doubt very very much that it's warped anyway, just give your caliper a good clean up and use Red Rubber grease on the outer pistons, do it once or twice a year and it will not misbehave.
(25-08-18, 09:43 AM)darrsi link Wrote: [quote author=deeteefifty link=topic=17296.msg283370#msg283370 date=1535183195]
[/quote]Don't worry all he wanted to do was show off his 15 inch Bacho adjustable
(25-08-18, 10:10 AM)fazersharp link Wrote: [quote author=darrsi link=topic=17296.msg283373#msg283373 date=1535186605]
Judging by his foot in the photo, that really is a large adjustable spanner isn't it?  :eek
(25-08-18, 10:30 AM)darrsi link Wrote: [quote author=fazersharp link=topic=17296.msg283375#msg283375 date=1535188240]
[/quote]Bacho is good kit - with an expensive price to match. That is an expensive spanner !
(25-08-18, 10:58 AM)fazersharp link Wrote: [quote author=darrsi link=topic=17296.msg283376#msg283376 date=1535189457]
Still won't straighten a disc though!
I better bend it back then Big Grin . Thanks, appreciate your concern darrsi. I overhauled the rear caliper with one of the stainless kits, took it for a run and felt the back pedal pulsing, feeler gauges between disc and pad showed 1.5mm gap (guessing its been bent during a tyre swap in its past) after straightening I checked for cracks with detector spray. Previous owner fitted a new chain believing the old one was the cause of a clicking noise, turned out to be the disc catching the pads.
