(03-06-17, 02:10 AM)Chris link Wrote: Decided it was time to take out the baffle. Man it's got some scream now!
[Image: IMG_3045_1.jpg]
Chris
Chris, you're not in London fella, a noisy exhaust where you live will upset the whole island......all at once  :lol
At least your workmates will know when to put the kettle on when you're leaving home to go to work  :lol
(03-06-17, 09:50 AM)darrsi link Wrote: At least your workmates will know when to put the kettle on when you're leaving home to go to work  :lol
Hahaha!!! Trust me, there are bikes with much louder exhausts than mine and it's not too offensive, definitely louder though, especially as the revs get higher under load.
Chris
[Image: 208008.png]
(30-05-17, 04:17 PM)kgjersda link Wrote: Changed the brake pads front.
I could probably have driven 10.000km more on the old ones. But they just didn't feel right.
New ones feel so much better and has better stopping power.
Now... should probably replace the brake lines as well..
[Image: oaliza7.png] [Image: mDrbGTr.jpg428-h570-no]
That's the way to do it, best pads on the market  Smile
Later
(03-06-17, 03:53 PM)Gnasher link Wrote: That's the way to do it, best pads on the market  Smile
Really enjoy them! I heard all about the great brakes on the bike. But until these new pads I wans't that impressed.
[Image: 613563.png]
The pistons in my front calipers were pitted (to say the least!), so I have made a set from nickel aluminium bronze, new seals fitted etc, and have got some new Hel brake lines to go on too - Looking forward to a better front brake.
(10-06-17, 04:49 PM)Grib link Wrote: The pistons in my front calipers were pitted (to say the least!), so I have made a set from nickel aluminium bronze, new seals fitted etc, and have got some new Hel brake lines to go on too - Looking forward to a better front brake.
Holy balls, are those damage from taking them out?
Did you make your own?
[Image: 613563.png]
No, not damage from taking them out, they have rotted away around the edges. And yes - new pistons made by my own fair hand.
Those pistons you've made look amazing, great job!
Chris
[Image: 208008.png]
Thank you. I would normally have just bought new ones but £200+ was just too much, I have already spent more on this bike than it cost me to buy and I had the bronze bar so it seemed the best solution.
(10-06-17, 07:06 PM)Grib link Wrote: Thank you. I would normally have just bought new ones but £200+ was just too much, I have already spent more on this bike than it cost me to buy and I had the bronze bar so it seemed the best solution.
I can see some requests coming your way  Wink  :lol  Top job fella!
Are you taking orders?  Smile That is a seriously impressive piece of work
Stripped the front end down in order to try and cleanup the headlights as they were covered in dusty crap on the inside. I wish I hadn't bothered now as the brackets that hold the unit were broken so I'm having a nightmare sticking them back together plus the front cover of the unit was completely glued in all around so it took me hours cutting through so I could just lift the front off. Because it was getting on my tits so much I've just left it in pieces for the moment until I can get back to it, problem is that it now means it's off the road again, but my buddy across the road has kindly let me borrow his MT-09 for the week so that has cheered me right up  :lol
RIP my beautiful red beast 1999 to 2017 ???
(11-06-17, 06:29 PM)Fazer99 link Wrote: Stripped the front end down in order to try and cleanup the headlights as they were covered in dusty crap on the inside. I wish I hadn't bothered now as the brackets that hold the unit were broken so I'm having a nightmare sticking them back together plus the front cover of the unit was completely glued in all around so it took me hours cutting through so I could just lift the front off. Because it was getting on my tits so much I've just left it in pieces for the moment until I can get back to it, problem is that it now means it's off the road again, but my buddy across the road has kindly let me borrow his MT-09 for the week so that has cheered me right up  :lol
Not something i would wanna try, but people on here have put the light unit in the oven before to soften up the glue you're on about, then separate it with a screwdriver.
https://youtu.be/ZIG3OQB7xz0
(11-06-17, 08:26 PM)darrsi link Wrote: [quote author=Fazer99 link=topic=17296.msg262451#msg262451 date=1497202161]
I would have heated the glue to soften it but it was that type of glue that dries like cement and no amount of heat was going to budge it. Managed to get it apart with minimal damage around the edges  :lol I'm glad I did do it now as you know that domb thing that goes over the bulb, it was hanging off and could have caused some problems if it had come off completely. going to get it all put back together tonight after work, but until then I'm enjoying borrowing my mates MT-09  :lol
(10-06-17, 05:58 PM)Grib link Wrote: No, not damage from taking them out, they have rotted away around the edges. And yes - new pistons made by my own fair hand.
Nice bit of work on them pistons mate, I hope you put the main seal in the correct way around?
Later
(12-06-17, 01:55 PM)Gnasher link Wrote: [quote author=Grib link=topic=17296.msg262374#msg262374 date=1497113919]
I got the new seals from Wemoto and the main seals are parallel not tapered, however when I put them in the groove (either way round) the inner edge was sticking up higher than the outer edge. The groove itself must be machined to hold the seal in the correct position.
Front end all put back together and now with nice shiny clean headlights which has made them that little bit brighter which was the result I was going for.
Not riding it to work today as as my mate has let be continue borrowing his MT-09 for another day, problem is that I don't want to give it back as its such an awesome fun bike, it's just so quick, light & flickable  :lol 8) :lol
I done a bad thing - people going to get all shouty and red in the face - welcome to 'RATTUS'
[Image: Rattus.jpg]
"Don't Die with Fun in the Bank!"
(13-06-17, 02:39 PM)ponkster link Wrote: I done a bad thing - people going to get all shouty and red in the face - welcome to 'RATTUS'
It's so over-the-top that I like it! :lol
Picture from the front please!
[Image: 613563.png]
