04-08-20, 09:16 PM
I've found the seals, I emailed them about the collar has it said ETA so waiting to hear from them to see how long it would take.
Swing arm Movement?
04-08-20, 09:16 PM
05-08-20, 10:35 AM
(04-08-20, 03:26 PM)b1k3rdude link Wrote: Do a search on ebay for the part number -Checking the link for the colloar above show an ebay link from Fowlers and it says they have 8 in stock atm - https://www.ebay.co.uk/itm/YAMAHA-Collar...SwQn1e-yxc And the second link has result after result of genuine seal going for peanuts!
05-08-20, 10:54 AM
(05-08-20, 10:35 AM)b1k3rdude link Wrote: [quote author=b1k3rdude link=topic=26394.msg318738#msg318738 date=1596551170]Checking the link for the colloar above show an ebay link from Fowlers and it says they have 8 in stock atm - https://www.ebay.co.uk/itm/YAMAHA-Collar...SwQn1e-yxc And the second link has result after result of genuine seal going for peanuts! [/quote] Mate, can you find these? (04-08-20, 06:06 PM)FILZ6 link Wrote: Wemoto.com are showing the seals in stock, £5.62 + £3.00 postage to the UK. Looks like the collar is out of stock though.
Later
05-08-20, 10:59 AM
Let me call Fowlers just now..
05-08-20, 11:03 AM
Mate I'm referring to the parts on Wemoto?
Fowlers will get any Yam part if it's still made and carried as stock in 24 hrs from the EU distribution dept in Holland, if they don't have it.
Later
(05-08-20, 10:35 AM)b1k3rdude link Wrote: Checking the link for the colloar above show an ebay link from Fowlers and it says they have 8 in stock atm - https://www.ebay.co.uk/itm/YAMAHA-Collar...SwQn1e-yxc (05-08-20, 10:59 AM)b1k3rdude link Wrote: Let me call Fowlers just now..So ebay is lying. Fowlers don't have any stock as Wayne found, but Yamaha Uk do. Lead time from purchase over the phone to arriving through your letter box atm is 7-10 days. - https://www.fowlersparts.co.uk/search/part/90387-102R4 But found another more linkfor the collor - https://www.cmsnl.com/products/collar1wg_90387102r4/
05-08-20, 11:22 AM
Looks like Yamaha have changed how the do business, Fowlers used to be one of the main spares importers they supplied most others. Oh well you learn something every day
Later
05-08-20, 11:56 AM
I've managed to get everything off, the collar doesn't look to bad just a good clean?
https://www.amazon.co.uk/photos/share/LY...SUIojrksrk
Gnasher will correct me -
I have a suspension linkage coming, should be here on Friday, maybe this will come with some collars,So I'm going to clean everything up while the swing arm is off, also have some new bearings for the pivot shaft which I might put on too.
05-08-20, 12:11 PM
You need to put a micrometer on the pin and measure it in several places, as they wear with flat spots and eccentrically. The darken area is wear (lack of grease) often the needles wear more then the pin, looking at the movement and the pin I'd say the bearing is shot. Quick way and only as a guide is clean out the bearing with brake cleaner, once all the old grease is out shake the bearing if it rattles it's shot.
Check the seals, if they're hard/brittle replace them or your new bearing will fail in short order.
Later
05-08-20, 12:26 PM
(05-08-20, 12:11 PM)Gnasher link Wrote:
05-08-20, 12:33 PM
(05-08-20, 12:26 PM)b1k3rdude link Wrote: [quote author=Gnasher link=topic=26394.msg318778#msg318778 date=1596625905]
It would, but to a point, measuring is the correct way.
Later
05-08-20, 02:04 PM
I'm just on with cleaning the swing arm, which seems harder than taking it off the bike :lol and noticed some black tape is that there for a reason?
https://www.amazon.co.uk/photos/share/1p...HxquiQNZSQ
05-08-20, 06:58 PM
Pull the tape off and have a look, probably covering a bit of surface rust.
05-08-20, 09:44 PM
Im fairly sure Ive seen the same tape on on one of my FZS1000 swingarms. No idea what its for, I might be covering a small drain hole, so your best just leaving it alone.
06-08-20, 09:01 AM
Is this normal for movement of the bolt through the collar?
https://www.amazon.co.uk/photos/share/Sv...x2DPdD8DRj
06-08-20, 09:43 AM
(06-08-20, 09:01 AM)WayneUK link Wrote: Is this normal for movement of the bolt through the collar? Theres some wear in there
06-08-20, 09:58 AM
For anyone that needs this info here is a breakdown of the parts and what Wemoto in-stock -
Dogbone mounts:
« Next Oldest | Next Newest »
