04-10-14, 01:27 PM
(04-10-14, 11:55 AM)bwizz link Wrote: I fitted the 2 plugs from the 600, started up fine then within minutes ,I lost no 4, This would seem conclusive that no 4 is flooding constantly and no 1 intermittently. This will have to wait till i'm in a better state of mind to take the carbs of,
Push a clear plastic pipe onto the drain hole and tape on to the side of the carb. Loosen the drain bolt and and let it fill the pipe check the level of the fuel in the line in relation to the float bowl. Now start the engine and see if the height changes when the engine is running and being revved. See picture attached.
If levels are wrong it is either dirt or dodgy float valve seals.
If it is seals change all 4.
