Increase in MPG/K&N
#41
Do you have the large rubber shroud/ skirt/hood fitted thing that also acts as a rubber grab for the side pannels
(23-01-14, 10:38 PM)fazersharp link Wrote: Do you have the large rubber shroud/ skirt/hood fitted thing that also acts as a rubber grab for the side pannels
Yep
The oily crap comes from over filling the oil or from excessive gases getting past the rings and pressurising the crankcase causing oil to get pushed into the airbox.  There's a pretty big kink in that breather too so it'll get blocked quick enough and then the lovely mayo builds up from water vapour not being able to get through the breather. That's my theory anyway and I'm sticking to it :lol
(23-01-14, 10:46 PM)darrsi link Wrote: [quote author=fazersharp link=topic=11419.msg122849#msg122849 date=1390513117]
Yep
Ok I was thinking -- somone on here was asking if they could do away with all that faff of a thing and although i know it wasnt you I thought maybe somone before you removed it, and then I thought ---yes that is what it is for - to prevent excess moisture.
Anyway its still only you (on this forum ) with a FZS 600 that "thinks" there is a difference with a K&N filter with reguard to responce and performance. Dont get me wrong I want to be convinced.
(23-01-14, 10:54 PM)His Dudeness link Wrote: The oily crap comes from over filling the oil or from excessive gases getting past the rings and pressurising the crankcase causing oil to get pushed into the airbox.  There's a pretty big kink in that breather too so it'll get blocked quick enough and then the lovely mayo builds up from water vapour not being able to get through the breather. That's my theory anyway and I'm sticking to it :lol
Now you see you have got alot of big words there and so im convinced
That's what i meant to say  :lol
(23-01-14, 10:57 PM)fazersharp link Wrote: [quote author=His Dudeness link=topic=11419.msg122854#msg122854 date=1390514084]
What like crankcase? That's not big and I think it might be two words :lol I thought we'd done the k&n debate before and someone had dynographs showing there was no increase in power but that it  gave a better power curve so you get better mid range whatever that means :lol I haveone because you can clean it and reuse it. If you don't have one I don't think you're losing out anything really
(23-01-14, 10:56 PM)fazersharp link Wrote: [quote author=darrsi link=topic=11419.msg122850#msg122850 date=1390513571]
Yep
If you want to be convinced........buy one!
Yet to fit  a K&n to my Fazer,really must do this Spring.
Previous vehicles so fitted defo gave better pickup plus slightly better mpg.
k&n negatives:
              temperamental wet weather starting, why? or if this also applies to fazer version  i do not know.
                Slightly alarming that when you hold a K&N up to the light you can see pin holes!  :eek Anyone?
(26-01-14, 11:24 AM)69oldskool link Wrote: Yet to fit  a K&n to my Fazer,really must do this Spring.
k&n negatives:
I've never had problems with starting in wet weather, that sounds like an issue elsewhere.
Two seperate vehicles, both fine with standard filter, but grumbled with a damp plus K&N combo.
No matter,
              i'm happy to take your word for it if it's not an issue with fazers.
Only really had minor grief starting in extreme cold weather, but even that was cured once i started using the choke, otherwise it starts on the button every time.
