Finally finished putting the 5 spoke R6 wheels on my gen 1 fairly straight forward got a couple of runs arranged this weekend so should see how they perform, probably won't feel any different but needed a challenge.
(22-04-16, 12:19 AM)Red Ceri link Wrote: Finally fin[size=1em]ished putting the 5 spoke R6 wheels on my gen 1 fairly straight forward got a couple of runs arranged this weekend so should see how they perform, probably won't feel any different but needed a challenge. [/size]
:useless
(22-04-16, 07:48 AM)unfazed link Wrote: [quote author=Red Ceri link=topic=6412.msg230000#msg230000 date=1461280783]
:useless
Yep I guess they will just around and around same as the original ones did, but I agree sometime just for the aesthetics and the challenge it has to be done.  :thumbup
(22-04-16, 09:08 AM)tommyardin link Wrote: [quote author=unfazed link=topic=6412.msg230011#msg230011 date=1461307726]
:useless
I bet they look awesome on the fazer,  what modifications do you need to do to make them fit?
Sent from my GT-I9300 using Tapatalk
Set Fazer's to stun
Hedgetrimmer has been in the swiss alps!
(22-04-16, 04:41 PM)matt7chunk link Wrote: [quote author=tommyardin link=topic=6412.msg230015#msg230015 date=1461312515]
:useless
Going on the LoFo run Sunday so will get some photos done then,
easyish install
Front wheel came with a set of 320mm discs so only needed some caliper mounting bracket spacers, available from Braketech in the USA (don't ask how much  :eek), otherwise a straight swap.
Rear little bit more complex but on sprocket side just needed original Gen1 Sprocket carrier and spacer, on the disc side the wheel came with a smaller disc so I ended up modifying a FZ1 ABS rear caliper mount by filing down ABS mounts then welding on a couple of 10 mm Aluminium plates to match original torque arm then had someone in work machine a large spacer for between caliper mounting bracket to swinging arm, plus a new rear brake line and FZ1 caliper, pain in the bum to get wheel on and off now but doable.
Everything I've done is reversible, so when (and if ever) I come to sell her I can put it all back to standard as I know Gen1s, or any bike, are more valuable standard when it comes to selling time
Done 180 miles today, can't really feel if they have made any difference as I also fitted new Metzler Roadtec 01's, new tyre to me, but overall bike felt really good.
Keep telling myself don't change anything else but already have a R1 Brembo front master cylinder on the way
(22-04-16, 05:11 PM)Red Ceri link Wrote: [quote author=matt7chunk link=topic=6412.msg230048#msg230048 date=1461339713]
:useless
easyish install
Front wheel came with a set of 320mm discs so only needed some caliper mounting bracket spacers, available from Braketech in the USA (don't ask how much  :eek ), otherwise a straight swap.
Looking 4ward to seeing the pics
Fixed the stuttering at 3-5k revs.  Smile New plugs and 2nd hand coils for the two centre pots. Now she's
ready for the trip to Selkirk next weekend.  :b
Life's a bitch. Enjoy it while you can.
(22-04-16, 08:29 PM)Panzerbuilder link Wrote: Fixed the stuttering at 3-5k revs.  Smile New plugs and 2nd hand coils for the two centre pots. Now she's
Was it the plugs the coils or a combination of both?
Maybe just the plugs. But I changed the coils jic. They were all, new and old, within the resistance check but I had bought them anyway. The bike ran better, or seemed to, after I had just changes the LHS two. And one of the plugs was outside the gap check. (0,7mm) So maybe that was it. I just didn't want to do the job twice.  :eek
(22-04-16, 08:51 PM)Panzerbuilder link Wrote: Maybe just the plugs. But I changed the coils jic. They were all, new and old, within the resistance check but I had bought them anyway. The bike ran better, or seemed to, after I had just changes the LHS two. And one of the plugs was outside the gap check. (0,7mm) So maybe that was it. I just didn't want to do the job twice.  :eek
Sounds like it was a good plan plus the coils you took off the bike are now in storage for any future issues that might occur. :thumbup
Went to the Norfolk coast from Lincoln ,did about two hundred miles with fish and chips at frenchies,well next to sea
Put some led strip into my instrument cluster. Now I can see what dials are actually reading at night, rather than a dull green haze.
(24-04-16, 12:26 AM)Aky208 link Wrote: Put some led strip into my instrument cluster. Now I can see what dials are actually reading at night, rather than a dull green haze.
Blimey it must look like this now  :rollin
Dull Green Haze!!!!
My 2002-2003 registered 600 FZS [size=1em]instrumentationlighting is very bright and clear, in-fact I wish there was a dimmer to take them all down a few lumins, and the main beam light is tooooooo bright[/size] :eek  the main beam warning light need its own set of flip down sunnys Confusedun [size=1em]like my bucket has.[/size]
Rode it on a new route through Devon and Somerset, a good day!  Smile Saw a nice red fzs 600 near North Fitzwarren. Anyone?
(24-04-16, 04:10 PM)Shez link Wrote: Saw a nice red fzs 600 near North Fitzwarren. Anyone?
No such thing :nana :finger
Must of been a typo, surely he meant NICE SILVER FZS600
Took it out for a quick spin , stopped at Cheddar for a coffee .
(24-04-16, 11:13 AM)fazersharp link Wrote: [quote author=Aky208 link=topic=6412.msg230184#msg230184 date=1461454019]
Whhaaattt??/  :eek
I couldn't see what speed I was doing last time I rode at night.
Wish i took a photo of it before hand. Will take a photo of what it looks like now, later tonight.
(24-04-16, 05:51 PM)Aky208 link Wrote: [quote author=fazersharp link=topic=6412.msg230219#msg230219 date=1461492807]
Whhaaattt??/  :eek
Did you say green, because the standard bulbs are white/yellow, I wonder if somone before you has put crap green bulbs in either hat or most of the original ones were blown
