stuttering fzs 600
(27-08-12, 08:43 PM)CRH link Wrote: dont understand this HG meself red?...but think its something to do with pull of vacuum!!..ie, a maximum and minimum between cylinders?.... Wink
yes mate .....its got to be something like that  Wink .........just waiting for someone to come along and enlighten me  Wink Wink
The determination of a gas pressure that is less in magnitude than the pressure of the atmosphere. This low pressure can be expressed in terms of the height in millimeters of a column of mercury which the given pressure (vacuum) will support, referenced to zero pressure. The height of the column of mercury which the pressure will support may also be expressed in micrometers. The unit most commonly used is the torr, equal to 1 mm (0.03937 in.) of mercury (mmHg).
Pinched this off the net I think it explains............... Big Grin
Andy
that is exactly what i was trying to say andy? :rolleyes :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin
I was just agreeing with you :lol
Andy
well thats fkd it then....looks like we both wrong!!!!!!!!!!,,,,,soz red!! :lol :lol :lol
thanks you two  Smile ......i know i need to aim for 240hg , but not sure of the reason why  :\ ....are all bikes set to this standard or do they vary.....no mention in haynes book of lies  :rolleyes
not sure !..but i would imagine it varies from engine to engine!! ,diff cc,s  etc.. mabe that number you been given is a ................Factory....setting!!!!... Wink who knows??
just serched pilot screw on here and found a post by GNASHER that ive read before and then forgot about  :\ .....topic title,RUNNING PROBLEMS / TPS ISSUE .lots of info here and easy to understand, THANKS GNASHER  8) . i need to pull 230-250 mm at 1150-1250 rpm,and must have pilot screws set correctly for balancing  Wink .... well worth reading this post  Big Grin
that sounds spot on then!!! theres your 240hg..and at idle speed !!! does sound like factory setting after all?....wasn,t there mention of a maximum discrepancy between readings?? Wink cant find my notes?..but think it was bt ...10% between cyls max!!
(27-08-12, 09:42 PM)CRH link Wrote: that sounds spot on then!!! theres your 240hg..and at idle speed !!! does sound like factory setting after all?....wasn,t there mention of a maximum discrepancy between readings?? Wink cant find my notes?..but think it was bt ...10% between cyls max!!
reading my scribbles it is indeed 10 between cylinders  Big Grin [size=78%]......10 what i dont know [/size] :o [size=78%].....will find my gauges tomorrow,they might give me a clue. [/size] Wink
looks like i will have to alter my pilot screws to 2 turns out for the balancing  :\ [size=78%].....anyone done this with carbs on the bike ? not a lot of room in there [/size] Smile
i would think thats 10mm hg on your scale red!!....i would still try the settings you been given first mate?....just may be good!!!!!ps, if you set all your carbs the same,ie 2/2 1/4..or even 2 1/2...i would leave them at that and balance them you could allways do fine tweeks later if needed?.....got to be nearer than what you had b4?...ie 4turns out!!!!!.....i think you will struggle trying to adjust them in situ???
(27-08-12, 09:56 PM)CRH link Wrote: i would think thats 10mm hg on your scale red!!....i would still try the settings you been given first mate?....just may be good!!!!!ps, if you set all your carbs the same,ie 2/2 1/4..or even 2 1/2...i would leave them at that and balance them you could allways do fine tweeks later if needed?.....got to be nearer than what you had b4?...ie 4turns out!!!!!.....i think you will struggle trying to adjust them in situ???
yeh think your right there mate  Wink ....will look tomorrow after work........glad i done the shims at the same time  Wink very ,very quite now  Big Grin
I managed to set 3 out of 4 screws ok but will need to remove the starter motor to set the 4th so I've as yet not done it. I've added it to my to do list for winter Smile
Andy
(28-08-12, 08:24 PM)Andy FZS link Wrote: I managed to set 3 out of 4 screws ok but will need to remove the starter motor to set the 4th so I've as yet not done it. I've added it to my to do list for winter Smile
Andy
had a look myself tonight  Smile and like you ill take the starter out to reset them  Wink ........how many turns have you set yours to  Smile
had to cut the front hedge this evening as swmbo was getting a bit frosty...so less time in the garage...but i did manage to put the coolant in and sort out my carb balancing gauges......will need to set mixture screws to standard for test,4 turns out at moment :eek  been like that for the last 10 years that i know of  Wink  so will set them to 2 1/2 slightly richer than standard  Wink
the easiest way to reset them seams to be to take the starter out and use a small flat bladed screwdriver  Smile  will see if i can do that tomorrow  Big Grin
no no no............................leave the starter motor alone. :rolleyes  get yerself one of those titchy spectacle repair kits for a quid or so and inside you will find a nice lickle flat blade screwdriver about and inch or so long that works a treat.....wouldn`t be without mine. or a small flexi shaft jobby ! Wink
I set mine to 2 1/2 turns but I think that's standard for mine (03) I tried using a small 1/4 drive socket screwdriver but couldn't manage all 4.
Andy
(28-08-12, 08:57 PM)ade the blade link Wrote: no no no............................leave the starter motor alone. :rolleyes  get yerself one of those titchy spectacle repair kits for a quid or so and inside you will find a nice lickle flat blade screwdriver about and inch or so long that works a treat.....wouldn`t be without mine. or a small flexi shaft jobby ! Wink
matey  :eek ......your alive  :lol :lol :lol :lol .....................i have a flexi shaft....hav`nt used it in ages  :rolleyes
thanks for the tip  Wink [size=78%]ade will find it out and give it a go[/size] Big Grin [size=78%] [/size]
(28-08-12, 09:00 PM)Andy FZS link Wrote: I set mine to 2 1/2 turns but I think that's standard for mine (03) I tried using a small 1/4 drive socket screwdriver but couldn't manage all 4.
Andy
going to set mine at 2 1/2 aswell  Smile .....going to try THE BLADES tip  Wink ....will let you know how i get on  Smile
re set the mixture screws last night....what a pain in the a*s  :\ ........did three of the carbs  with a small screwdriver no problem  Smile  cylinder no 3 was a pain,can see the screw easy but once i get my hand in there i cant see bu**er all  :\  so took the starter out,which helped but still could`nt adjust,ended up loosening the inlet rubbers on the carbs and easing the carbs back and as high as i could  :\  i was than able to adjust no 3 Big Grin
all back together now and ready to balance the carbs  Big Grin  all being well i`ll do that tonight and also do another  compression test to see what difference re-seating the valves has made  Wink
