12-10-22, 10:44 AM
Quote:Oh i see, it's not something i've ever used so not familiar with it. Handy to know though.Are you risking anything with the Optimate when charging though, with the higher fuse?And out of curiosity where does the lead sit for easy access?
Given the Optimate self regulates the amount of current it uses to put through, I'm guessing upping from 5 to 10 won't be an issue. But I'm no electrician.
The only issue might be a short across the connector terminals, but again I'm hoping a 10a is sufficient.
On the Fazer it's near the headstock, protected by a cap. Next to the same type of connectors for the heated grips
