(03-04-20, 01:16 AM)fazersharp link Wrote: Just watched some utube stuff but having trouble getting it through my receiver to output to my surround sound. I usually select on the receiver the input blu ray or set top box or tv. In this case I select tv but nothing, can't get it to go through the sound system, usually its via arc.
That may just be a case of patiently going through the settings, and maybe a bit of Googling as well.
I have a Sound Bar that i use with my tv in my bedroom which i found, after a lot of digging, for some weird reason it is incompatible with the Netflix app on my Panasonic 4K tv. I can't get any sound to it at all, but only on Netflix, everything else is fine.
But if i use the Netflix app that is on my Freeview Recorder box it works absolutely fine, even though it still passes through my tv on its way to the sound bar?
I went through every setting possible, changed cables, tried analogue instead of optical, but after looking on the internet i finally found out that it wasn't just my equipment, it was a known problem and if your set up was affected then the two items simply wouldn't work together and nothing could be done about it.
