I have a selection of syringes, and pipes - great for this or small amounts of filler - silicone - whatever in to small spaces.Noooo stop making your own jokes.Undoing the bolt is messy- it is when I do it
'kin ell ! I thought for a bit you was going to go on and on and on and on and on and on and on and on and on about oil levels :rollin :lol
(30-10-18, 02:01 AM)coffee link Wrote: 'kin ell ! I thought for a bit you was going to go on and on and on and on and on and on and on and on and on about oil levels :rollin :lol
You'd think it would be a simple thing, but I betcha there's still a lot of people who fill the oil up to the level without starting the engine and then reading the window, which would make it under filled.
All technical stuff. :lol
I understood you had to take the bike OFF the centre stand, with it on its wheels only, to measure the oil level through the sight glass.
On it's centre stand (for us lucky Fazer owners) its tilted a little backward, on its back wheel.
The Yamaha advice above says it should be on the centre stand......
(30-10-18, 02:51 PM)F4celess link Wrote: I understood you had to take the bike OFF the centre stand, with it on its wheels only, to measure the oil level through the sight glass.
Theres something wrong with your bike then, by default, the front wheel is on the ground when on the mainstand with the rear in the air.
On level ground even with my large top box half full, which hangs totally past the rear of the bike, it will always rest on the front tyre on the centre stand.
(31-10-18, 03:30 PM)dangerousdave link Wrote: I had a problem with the sight glass going cloudy and stained over the winter stand up.I ordered the part below from at [color=rgb(74, 74, 74)]https://yambits.co.uk/fzs1000-fazer-engi...15258.html[/color]Products ------------------------------------------------------ 1 x FZS1000 Fazer Engine Oil Level Window (MLP043) = £11.99 (Inc. VAT)£9.99 (Ex. VAT) ------------------------------------------------------ Sub-Total: £11.99 Delivery (Royal Mail SIGNED FOR to Mainland UK): £4.92 INCLUSIVE OF VAT @ 20% IF APPLICABLE: £2.82 Total: £16.91I didn't fit it myself but my mechanic said it was a lot easier to fit than he thought it would be.Dave...
As long as the bike doesn't develop a leak i'm quite content in putting 2.8 litres of oil in, with a new filter, and it does the trick without any need for a top up between changes (4000 miles for me).
