23-10-17, 12:22 AM
OK....had it sorted tonight.....for a while.
Had the LHS dimmer switch off, RHS light switch off and all the connection points exposed. Was not getting 12v at light switch so followed that back all the way back to the fuse box where I found a blown 10A fuse....whit a fud a thought. For some reason I thought that the HL fuse was the 20A fuse. Also the circuit diagram colours on the Haynes manual vary greatly from the actual on the bike which has caused me no end of hassle. I have now resorted to pulling bundles of cables to see where they lead then testing for 12V / continuity etc.
So I eagerly replaced the fuse and put together all the fiddly bits and the head lights were all working fine as was the horn etc. One thing that I did notice was the back brake light was not coming on with the back brake operation. It was working with front brake operation. I guessed that this problem was unrelated to the original no headlights and that I could address this later.
So I had in front of me a reassembled unit and was testing all the switches for the third time when the original problem reoccurred with no head lights horn etc. FECK!!!.
So now am thinking I would like to change the large connection plug under the LHS in-fill fairing as the connections there are pretty bogging.
Any other thoughts advice will again be most appreciated regarding possible cause, plug specification and method of replacement.
Ta as always...
Ta as always...
