23-04-17, 09:13 AM
Suspected Cam/Timing chain chatter
23-04-17, 09:13 AM
23-04-17, 09:15 AM
I happen to have a complete bottom end if that's of interest to you ?
Stuff everything I've always got my bike
23-04-17, 11:38 AM
Cheers guys. I'll speak to Dave tomorrow see what he says but if I need replacement parts I'll message you about that bottom end!
23-04-17, 02:00 PM
(23-04-17, 11:38 AM)Newb21 link Wrote: Cheers guys. I'll speak to Dave tomorrow see what he says but if I need replacement parts I'll message you about that bottom end! I'll never use it so I'd prefer someone who needs it or parts gets the use ?
23-04-17, 04:59 PM
Right, another update. Took it over to my dads today as a test ride and second opinion. While we were there, we balanced the carbs, using the guide that was posted on here. On the ride home it seemed a lot smoother than it has since I've owned it. The noise seems to be quieter, it is still there, but as far as I can tell when I get to 65mph-ish it seems to disappear. I'm stumped. Will give you another update once Dave's looked at it to.
24-04-17, 06:27 PM
Hi again guys. Took it into college and had my tutor spend a day on it with me. There was some cam chatter. But that was down to me not resetting the tensioner properly, so thats a plus. However there is still a knocking soind and after listening to it through a proper mechanics stethoscope he believes it's either small end or, he thought right at the end of the day, after one last check possibly starter clutch.
It now seems to be a constant knocking in time with engine revs. But if you blip the throttle, when the engine goes back to idle there's a clunk as well as the knocking. Looking for more opinions on that please. Also, wanted to say thanks for all your help so far, you guys have been fantastic! Hope we can sort this, I bloody love this bike lol.
24-04-17, 06:47 PM
deffo sounds like a big end if you got gold powder in the oil its 100 percent big end starter clutch dont make a noise clutch basket rattle only happens at idle and if you pull the clutch in it goes away deffo time for a strip down if your very lucky it will only be shells but with you running it allot more than likely their will be damage on the crank you tube rod nock and listen to it bet it sounds the same as yours rod knock is big end failure
24-04-17, 07:07 PM
(24-04-17, 06:47 PM)daviee link Wrote: deffo sounds like a big end if you got gold powder in the oil its 100 percent big end starter clutch dont make a noise clutch basket rattle only happens at idle and if you pull the clutch in it goes away deffo time for a strip down if your very lucky it will only be shells but with you running it allot more than likely their will be damage on the crank you tube rod nock and listen to it bet it sounds the same as yours rod knock is big end failure Yep that deep knocking noise means you have con rod movement, could be at either end but most likely a shell bearing at bottom rather than at the piston pin. You'll know if you've damaged the crankshaft, If you've flared up a bearing surface the bike will feel wobbly as well as noisy, I don't think you're there yet but I wouldn't rev her too high.
24-04-17, 08:59 PM
Dave kinda ruled out bottom end because we did an oil pressure test which, he said was absolutely perfect. Says if big end had gone oil pressure would be all over the place.
I've messaged Bikemad about the bottom end he saidnhe has just in case.
24-04-17, 09:21 PM
Basically if it knocks you've got crank wear riding more will only lead to catastrophic failure & potential damage of more than just the crank !
I always remember a GT250 my friend once looked at ? we walked away to say it knocked,rattled & piston slapped was an understatement,I heard a week later it seized & nearly spat the owner off violently locking it's back wheel at speed ??????? lmfao
24-04-17, 09:25 PM
I've had a dodgy starter clutch before. I think they go bad from starting the bike with a weak battery too often. Most of the time it was fine, there was no noise from it, then when it acted up it'd give off a deep rumble in time with the engine rpm however on mine if you turned the engine off and turned it back on it'd go back to normal with no noise. Also there was no metal in the oil. Yours sounds a bit worse than that but hopefully the starter clutch is your problem because it'd be a cheap fix. If I was you I'd try the trick with rotating the piston to bdc and push down on it with a screwdriver and feel for movement.
24-04-17, 09:41 PM
Yeah sounds like a good idea I'll give it a go tomorrow cheers.
25-04-17, 02:27 PM
Hi guys. I've had another listen to the engine with a stethoscope and am starting to think along the same lines as most have said here, that it's bottom end. It is very difficult to pinpoint though so I've made a video of the noise. Ignore my had waving about towards the end. Thought the exhaust had started to blow, but it was the fan kicking in lol
https://youtu.be/2KM3lGqYIiw
25-04-17, 05:34 PM
100 percent big end stop running it you more than likely killed the crank aswell best bet is a new engine and use that one for spares
25-04-17, 07:51 PM
:eek geeeezzzzz that don't sound good defo strip & rebuild or another engine job !
26-04-17, 07:25 AM
Yeah I'm thinking I'll speak to Dave today and see if I can get in into the workshop & pull the engine for a look. Will try and get tomorrow off work to service & MOT the 125 until I can sort the Fazer
01-05-17, 07:54 PM
Managed to get the barrels off today & common consensus was correct, big end has gone on 2nd cylinder.
06-05-17, 08:25 AM
OK, update time. Got a new bottom end on the was from Bikemad so we should be back together next weekend. But having trouble finding piston circlips that will be here in time. AJSsutton are saying 7-14 days and can't seem to find specific FZS ones on the bay, any other model/engines that use the same clips?
06-05-17, 07:16 PM
https://www.fowlersparts.co.uk/parts/view/90468-12069
they have them in stock and in the link shows what other models use the same
09-05-17, 03:51 PM
Cheers I managed to find some on EBay before I saw this post, which I hadn't though, paid £8 for 4 :'(
« Next Oldest | Next Newest »
