Fitting some hand guards
#21
I'm sure that muffs work better on some bike due to fairing design or more to the point how wind flow effects them. I had a pair from Oxford that used to hit the kill switch on my fz750 yet stayed in place at three figure speeds on my zx10
Great if you can get on with them
I.M.H.O any one thinking about purchasing heated grips is to go for it. I never used them myself up to last year but now would not be without them. Its my first upgrade on the fazer I have just bought, along with fender extender that is. They are a cracking bit of kit and there where times in spring and autumn I had them turned on whilst riding my other bike. If I can make my ride more comfortable and pleasurable that's the way to go.
                                                  Steve
Your only here once! GET A LIFE GET A BIKE in it.
Ok out today dry but cold and had a purposeful look and feel at the way I grip and its mainly with my palm and thumb and from my knuckles to my fingertips I don't really touch the grips. Baring in mind my shit circulation in that area and my actual hands don't get cold I still don't see how heated grips will help me. I don't even use my hands much what with clutch-less changing and 2 finger braking with braided lines, I have tried wiggling my fingers around to see if that helps.
Perhaps I will just stick to short 1/2 - 1 hour blasts in the winter, after all I don't have to ride when its cold as I don't commute - but then again if I was communing I don't think my hands would get so cold as they would get used more with stop and starts and less wind blast.
(05-02-17, 08:30 PM)fazersharp link Wrote: Ok out today dry but cold and had a purposeful look and feel at the way I grip and its mainly with my palm and thumb and from my knuckles to my fingertips I don't really touch the grips. Baring in mind my shit circulation in that area and my actual hands don't get cold I still don't see how heated grips will help me. I don't even use my hands much what with clutch-less changing and 2 finger braking with braided lines, I have tried wiggling my fingers around to see if that helps.
So you have different hands to everyone else?
You don't touch the grips when riding? That's clever!  :lol
Heat travels, if your palms are being blasted with heat then the attached fingers will obviously get some warmth as well.
These are the one's i have, and they get VERY hot on the highest setting, it has to be extremely cold for me to even think about that setting.
Bargain price too.  :thumbup
Just read somewhere else that these are rebranded but still made by Oxford.
http://www.ebay.co.uk/itm/DR-BIKE-HEATED...B-iIQ9whcw
(16-02-17, 06:58 PM)darrsi link Wrote: [quote author=fazersharp link=topic=21710.msg251845#msg251845 date=1486323041]
No like I said my fingers from knuckles to the tips do not really touch the grips its thumb, palms and half my fingers, and warming my palms up wont help my finger cause I have got crap circulation.
(16-02-17, 09:53 PM)fazersharp link Wrote: [quote author=darrsi link=topic=21710.msg252727#msg252727 date=1487267908]
It doesn't cook your blood, your hands will get hot inside the gloves creating warm air.
Stop making excuses, i'm fairly sure we all use the handlebars very similarly, we have to use the front brake and clutch too.
[color=rgb(30, 27, 29)]"...The new generation of Dr Bike Heated Grips are essential for colder weather and feature fully adjustable temperature control. The unique expandable grips are constructed from anti-split anti-perish rubber and fit easily on to 22MM bars and include a rainproof button control system, which is easy to use with gloves on. These are suitable for use on motorcycles as well as snow mobiles and ATVs and can heat up to 55 degrees in temperature to keep your hands nice and toasty! With a unique expandable design and fool-proof wiring loom they are extremely east to fit (please read instructions carefully) and the drain on your battery is minimal (up to 1.5 amps)..."[/color]
.png   Capture.PNG (Size: 2.85 KB / Downloads: 45)
.png   Capture.PNG (Size: 2.85 KB / Downloads: 36)
The reason they get that hot is because on a sub zero day they also have to deal with the cold metal of the handlebar, so as you can imagine on an average days temperature these will fry your hands through thick gloves if the setting is too high, but luckily there are lots of settings that can be easily changed without removing your gloves.
I just stuck the little control unit to my right side fairing infill panel using velcro so that it has more protection from bad weather and is out of the way but still very easy to access, but it is waterproof anyway.
Only main recommendation is that you DO NOT wire straight to the battery, you wire so that it cuts out when the ignition is turned off.
At those sort of temperatures you don't wanna be leaving them switched on by mistake.
Just thought that te reason that I do not grip all the way round is because my grips are thinner than the fatter heated ones, either that or you have short stubby little fingers.
(18-02-17, 11:21 AM)fazersharp link Wrote: Just thought that te reason that I do not grip all the way round is because my grips are thinner than the fatter heated ones, either that or you have short stubby little fingers.
If anything, if the heated grips are a millimetre or two thicker then that would be better on the hands, although it's not something i've ever noticed or even thought about.
To me they're just grips, i don't think they are oversized in any way?
....just to add to this for original question-
FZS600s don’t lend themselves to hand guards but it can be done...….a TDM or Versys for example or other bikes like them are easier as the front fairing is narrower.
So that your Fazer hand guards don’t foul the fairing when turning the bars you’ll want to buy some slim...ish hand guards as your starting point. Once you’ve fitted them and fine tuned the position - dremmel or cut any remaining part of the hand guard which makes contact with the fairing when turning the bars.
What you get in return is gloves that will dry out more quickly after riding through heavy rain. From my experience the benefits of stopping wind chill on your fingers aren't as good as one would expect but it certainly helps…..and depends how cold it is etc.
The other issue is that they change big time the styling/appearance of the Fazer but if hand guards are what you want then you have to get used to that.
The road to success is always under construction.....
Happiness is finding you have another gear left....
If there's no solution then its not a problem.
