Help me FOC-U you're my only hope
#21
Follow the PM I sent and it is easy to remove it yourself.
Where is the alarm located on the bike?
The alarm was wired in all over the place so you couldn't tell if it was an alarm wire or something for the bike, so the PM you sent couldn't help me unfortunatly, but thank you again for it.
All sorted now, there was another fault that was found other than the alarm. The main wire from the connector to the rectifier leading to the starter solenoid was not reading a constant currant so new wiring put in place and now it's sweet.
Only one slight issue now and that is the right front indercator is not working, but that should be an easy fix.
:woot :faz :woot
RIP my beautiful red beast 1999 to 2017 ???
Finally got the indicator working.
After hours of stripping down the front end and cutting into the protective tube to find the wires, it turned out to be a loose wire in the connector plug thing (technical term  :lol ) under the tank which would have taken be 5 mins tops to fix, bloody tipical  :b
Thank you to everyone for all and any help and advice given  Big Grin
