brake fluid bleeding problems
#21
If it that tight leave it as it is and tie/hold caliper higher than master cylinder to bleed it.  Or use syringe to try pull air bubble out.
went to a work shop. got all done.
even the mechanic had a tough time loosen those few screws....
and probably learnt something new. with his bleeding technique he pressed the pedal very lightly.
his theory was air bubbles come easier. if u were to press hard they might reach the end of nipple and go back in again. i guess must be true as i ever seen bubble going back in again. However i thought the solution was to press the pedal harder.[size=78%] [/size]
