09-02-15, 10:20 PM
Buy Mine!!!! lol
k&n are they worth it?
09-02-15, 11:10 PM
10-02-15, 12:23 AM
I'm currently in possession of farjo's carbtune which you're welcome to use, but you'd have to come visit!
Some say...
10-02-15, 12:27 AM
The filter in the photograph is age and petrol fumes discoloured making it look worse than it actually is, therefore having little effect on the running. A bad filter will only effect the running at 10 to 13000 revs and then get progressively worse lower down the rev range as the filter continues to get dirtier. :eek
If you do not regularly use the bike above 10000 revs then the difference in the filter you had and a new one would not be really noticeable. :rolleyes However what you would notice with the K&N is a slightly better throttle response throughout the rev range and a little less vibration. If you do not notice these changes then you most likely do not rev much above its 7000 power band :pokefun
10-02-15, 12:28 AM
10-02-15, 11:09 AM
(10-02-15, 12:27 AM)unfazed link Wrote: The filter in the photograph is age and petrol fumes discoloured making it look worse than it actually is, therefore having little effect on the running. A bad filter will only effect the running at 10 to 13000 revs and then get progressively worse lower down the rev range as the filter continues to get dirtier. :eek Now I am convinced
10-02-15, 11:55 AM
The other alternative is a Pipercross.....Mike fitted these for the Ivanising of us Scottish Foccers so they must be as good as the K&N but a bit cheaper.
(10-02-15, 11:55 AM)bigbluebear link Wrote: The other alternative is a Pipercross.....Mike fitted these for the Ivanising of us Scottish Foccers so they must be as good as the K&N but a bit cheaper. £2 cheaper, but the K&N nabs the vote for the first 50,000 mile cleaning interval.
11-02-15, 10:12 PM
K&N's flow more air how? The surface area of the pleats is no better than a paper filter so obviously the material flows more air i.e. they have bigger holes. There was an article in Classic Mechanics last year on air filters and they shone a bright light through a K&N and a paper filter. There were very noticeable visible light holes in the K&N, if you can see them then dust and grit can get through.
So its a trade off between possible slightly better performance (dependent on many other variables) or longer engine life. You pays your money and you takes your choice
11-02-15, 10:55 PM
(11-02-15, 10:12 PM)tony_d123 link Wrote: K&N's flow more air how? The surface area of the pleats is no better than a paper filter so obviously the material flows more air i.e. they have bigger holes. There was an article in Classic Mechanics last year on air filters and they shone a bright light through a K&N and a paper filter. There were very noticeable visible light holes in the K&N, if you can see them then dust and grit can get through. You realise you're talking to people with 12-17yr old bikes that are still going strong? :lol
11-02-15, 11:01 PM
(11-02-15, 10:55 PM)darrsi link Wrote: [quote author=tony_d123 link=topic=15923.msg183182#msg183182 date=1423689155] You realise you're talking to people with 12-17yr old bikes that are still going strong? :lol [/quote] mines on its 3rd engine!! 1 change by me
12-02-15, 01:39 AM
(11-02-15, 11:01 PM)Paulfzs link Wrote: [quote author=darrsi link=topic=15923.msg183185#msg183185 date=1423691715] mines on its 3rd engine!! 1 change by me [/quote] Mines on its first and now with 86000miles and a K&N in it since its second oil and oil filter change at 4000 miles. The reason K&N use oil on their filters is to trap the dirt. Well documented fact :lol [/quote]
12-02-15, 07:46 AM
(11-02-15, 11:01 PM)Paulfzs link Wrote: [quote author=darrsi link=topic=15923.msg183185#msg183185 date=1423691715] You realise you're talking to people with 12-17yr old bikes that are still going strong? :lol [/quote] mines on its 3rd engine!! 1 change by me [/quote] Just for the record and possible future reference: should the 'engine' be comparable to the broom head, or the broom handle?
including ones who like chocolate....
12-02-15, 07:53 AM
(11-02-15, 11:01 PM)Paulfzs link Wrote: [quote author=darrsi link=topic=15923.msg183185#msg183185 date=1423691715] You realise you're talking to people with 12-17yr old bikes that are still going strong? :lol [/quote] mines on its 3rd engine!! 1 change by me [/quote] What are you doing to the poor thing?
(11-02-15, 10:55 PM)darrsi link Wrote: [quote author=tony_d123 link=topic=15923.msg183182#msg183182 date=1423689155] You realise you're talking to people with 12-17yr old bikes that are still going strong? :lol [/quote] Of course, there will always be the 95 year old granny who smokes 40 Woodbines and has a tot of whiskey every day and is still going strong. Wouldn't like to see the inside of her lungs though. All I'm saying is you make your choice with all the facts ![]()
12-02-15, 10:07 AM
That may be the case with the grannies, but 3 engines, Midden in this case I would think the Broom Head, not being pushed properly :lol
12-02-15, 11:37 AM
I am now not convinced again
12-02-15, 01:19 PM
haha dont blame me
![]() i got it on its 2nd engine which lasted 400 miles before imploding randomly, had oil was being raced a little bit at the time but id barely gone above 70 before this happened. this 3rd engine though is running amazingly but clearly running lean!
12-02-15, 01:56 PM
Hi My current 54 plate fazer thou has just clocked 20thou miles and a previous 02 model clocked 23thou and i am still using the same K&N filter. Never had engine issues on either bike. Regular maintenance by a good mechanic is the answer to most of the problems on any bike.
Regards Mike
Mike Lockyer
12-02-15, 02:13 PM
So how much do they cost (incl oil cleaning kit) compared to an OEM one then.
Plus it looks a faf to clean and you then have to dry it and in the meantime you have a big hole to your engine and a mouse might get down there or something.
« Next Oldest | Next Newest »
