What we want but hasn't been invented yet!
#21
(30-11-14, 06:31 PM)darrsi link Wrote: [quote author=bigbluebear link=topic=15403.msg175646#msg175646 date=1417364178]
For the past ten years I've been working on frostfree Tarmac, and for the past three years I've used it on my drive and surrounding roads which has been very successful. I used this in a spray format which lasts ten times as long than salt and grit but the true test is on the roads where traffic wear will be probably the deciding factor. I have also used this formula on pavements and even with a few inches of snow it has remained not just snow and frost free but also dry. I have just started to mix this in with the Tarmac to see what longevity this will have but testing this method  is proving to be very expensive. This would be a revelation in road surfacing world wide and paramount to road safety during winter months.
I know this will carry huge costs for all the councils and local authorities to convert the traditional grit lorries to a liquid spraying solution and resurfacing all the roads if my Tarmac mix works, but millions is spent each year and is more a reactive  solution where my Tarmac mix is proactive and permanent. This means that even sudden heavy snow falls it doesn't lie and instantly dries too.
However I am convinced that I am really onto something and the Canadian authorities have indicating they could provide funding for the final testing on a stretch on one of their roads.
It's an exciting time for me and have set up a company to do more testing and market this worldwide.
As fellow bikers I'm sure you would agree it would transform winter biking.
Crikey,you patent that one and you'll end up a billionaire!  :deal
That's the hard bit, all patents are pending at the moment, I didn't believe how hard it would be. Tarmac is a patented brand and been to see them but all they want is my recipe for their own testing.....aye right!!!!! Inventing a new type of road surface is virtually impossible but I'm sure a deal could be done with Tarmac but they're play hardball at the moment.
Even the gtitter lorry spreading mechanism is patented along with a whole load of other shit in processing......that's why it's taking so long........dragons den beckons
Here's what I want, a mirror extension for the current elbow view ones, these would be molded to the outside shape and would Velcro into position - a 2 minute job to fit
(30-11-14, 07:27 PM)bigbluebear link Wrote: [quote author=darrsi link=topic=15403.msg175656#msg175656 date=1417368678]
That is really cool. Good luck
I'd like some shares in BBB's invention!
A automated highway system that would self-operate, provide the power for vehicles on its grid, and not have any accidents. Imagine the highways in "I, Robot" without the going vertical bits, and without the psychotic lorries!
The Deef's apprentice
(30-11-14, 11:00 PM)ChristoT link Wrote: A automated highway system that would self-operate, provide the power for vehicles on its grid, and not have any accidents. Imagine the highways in "I, Robot" without the going vertical bits, and without the psychotic lorries!
Yeah right, and imagine a world without bikes  :rolleyes
Oh yeah, you don't have to  :rollin
(30-11-14, 11:03 PM)nick crisp link Wrote: [quote author=ChristoT link=topic=15403.msg175698#msg175698 date=1417384827]
:finger Foc off.
I mean as an urban network. Drive to a major town, park the bike, get into a "pod" that takes you straight to where you want to go. Like park and ride buses, but actually functional! Would reduce traffic jams as no accidents, and a computerised control network.
" PUB POD"!!!  :thumbup
Lol OUCH!!!
Arai to create a visor that expels beads of water by turning your head, rather than water sticking like glue to it.
I've had several over the years and they've been no different.
With my old Shoei lid, water would just fly off it no problem! :\
Remote central locking for your house, doors lock and windows shut and lock
I designed, built prototypes, got patents and sold two patents for 100cc go kart applications about thirty plus years ago.
1. Application for operating the throttle by way of hand operated lever mounted on the back of the seat. Those that have had to bump direct drive 100cc karts will know what I'm on about. When you bump these you have to run along, one hand on the steering wheel and the other on the back of the seat holding the rear wheels off the ground and then drop the back turning over the engine by way of the back wheels. When the engine fired the knack was to jump in and hit the go pedal before the engine died or you lost momentum... sometimes easier said than done. Unless you have Kosmic's Easy Start system. Dump the kart hold the lever and the kart bursts into life and travels forward at fast walking pace (jogging) with the motor nicely ticking over. Jump in holding the lever until you can get your foot on the throttle and away you go.
You can't see the hand operated but to the right of the tank you can see the throttle linkage. The lever operated the throttle cable without interfering with the foot pedal and vise versa.
[Image: MainPickart_zps0e99f52a.jpg]
[Image: Easystart1_zps28b60934.jpg]
2. Steering wheel mounted choking lever. At maximum revs when racing these karts, at the end of a long straight before backing off the throttle the engine bore needs to be cooled or there is a great potential to seize the engine because the fuel is pre-mixed. When you gas off there is not enough oil running through the engine to lubricate the piston and bore. The knack was to cover the air intake with one hand to flood the engine, a rich intake of oil and petrol would cool the bore. Thing is you have to pretty accurate when doing this. Too much and the engine would flood and stall and spit you into a spin then maybe restart mid corner often with a lock up sideways or lots of power causing bad oversteer... Not what you want as this costs laptime and unsettles the kart.  The Kosmic's Easy Choke was fully adjustable to give you just the right amount of richening. On longer straights such as Rye House more choking/cooling was needed and on shorts straight as at Lydd less cooling was needed. The finger operated lever mounted on the back of the steering wheel activated a butterfly valve on the air intake. This meant both hands could be kept on the steering wheel just at corner entry where you need to be precise.
(01-12-14, 12:22 PM)fazersharp link Wrote: Remote central locking for your house, doors lock and windows shut and lock
:lol
Or remote light off for when your daughter leaves various lights on throughout the house.
(01-12-14, 12:50 PM)Kosmic Kartman link Wrote: [quote author=fazersharp link=topic=15403.msg175738#msg175738 date=1417432939]
:lol
You can already get something like that I think that you press it and the button slowly pops out and then turns the light off, you can also fit remote sensors that turn them on and off.
And apart from any of that there is something that already does it --- its called Dad.
Light reactive visor that quickly adjusts to light levels    Wink
Its just a ride
(01-12-14, 03:16 PM)bigralphie link Wrote: Light reactive visor that quickly adjusts to light levels    Wink
My insert does that already, very mildly but certainly enough to be helpful!
http://www.ebay.co.uk/sch/i.html?_from=R...t&_sacat=0
they might be better now but I tried one a few years ago and it just never got dark enough  Smile
Its just a ride
(01-12-14, 06:02 PM)bigralphie link Wrote: they might be better now but I tried one a few years ago and it just never got dark enough  Smile
I have the clear one, and the tinted one which was certainly good enough in summer.
Apart from the anti fog properties I also like the fact that they get rid of headlight glare at night as well.
There's a bit of a knack to fitting them, because you need to get it right first time with the double sided tape, you can't just peel it off to readjust it.
And you need to have the visor totally clean, and dust, hair and shit free, otherwise you're doomed to have to stare at it.
I've got it down to a bit of an art now, and every 1 or 2 years i'll reapply and shape new double sided tape in one long length on my visor so that it stays air tight.
Because I ride all year round water will eventually find a way in, normally around the top somewhere, then it's time to change the tape again.
I use Sticky Stuff Remover to get the old gunk off, as it doesn't hurt anything.
Electric lorries and Solar powered induction charging laybys for them to pull up for rest periods. 'Shoulder blade' a velcro on plastic cover and upright blade which protects a cricketer while allowing free movement of the head. 4 cylinder bike engines that will switch to two in town to conserve fuel.
The Frying Scotsman
Wearable wing mirrors.......no more mirror extensions or looking at elbows as they will always be further out if they are attached to your elbows. 8)
(30-11-14, 12:18 PM)darrsi link Wrote: [quote author=Dead Eye link=topic=15403.msg175608#msg175608 date=1417345780]
It's the quirky things in life that I can never manage to think of from the top of my head... my immediate response to this was cheap, clean fuel :\
Would that not be called electricity?
Not really given how the bulk of electricity is produced
But yeah, this already exists I guess - Solar, Wind, Hydro and Tidal power Smile
