12-09-14, 10:09 PM
You can fit an advancer and use the same technique to find the sweet spot but start with Ivan's way and see how you get on first.
Vibration (again)
12-09-14, 10:09 PM
15-09-14, 01:32 PM
(10-09-14, 02:18 PM)Falcon 269 link Wrote: You could try different grip material.I tried these with resonable success. http://www.grip-puppy.co.uk/ (10-09-14, 02:18 PM)Falcon 269 link Wrote: Once you've found it, tighten the TPS screws, reduce the idle back to 1,250 - 1,300rpm and then go round to apologise to the neighbours.Are you sure about that idle figure for the Gen1? I thought it was supposed to be about 950rpm?
16-09-14, 05:12 AM
Stock is 1050 - 1150 rpm according to workshop manual.
The higher figures help maintain oil pressure at idle and the transition from idle to part-throttle. 950rpm is way too low.
16-09-14, 06:15 PM
May give those grips a try, thanks for that.
Received my advancer today, so that may shed a few more vibes. It is better after the carb balance and it does vibe less with a full/half full tank.
17-09-14, 12:04 PM
(16-09-14, 06:15 PM)woodwizzard link Wrote: May give those grips a try, thanks for that.As a matter of interest, how long is it since you last changed your plugs? (miles/years)
17-09-14, 07:25 PM
Changed them 3 days ago. Took iridium ones out and went back to normal ngks'. Not sure when they were last done. Normally change plugs every 2 years. Fitted the advancer today and am getting some grip puppy things. Should be as smooth as a smooth thing now.
« Next Oldest | Next Newest »
