02-08-14, 07:44 PM
To check the calibration of a four dial set-up I made an adapter to take the four pipes and a shut off tap at one end and fitted the other end to an empty co2 bottle from the mig welder. Then with some water in the bottle and the tap open I heated it up until steam came out, then shut the tap. As it cooled down the four gauges all measure the vacuum created by the cooling at the same time. I can't remember if I had to make some fine adjustment but I do remember they were very close to start with.
If a photo is needed it will have to wait, because I am not about to do it right away.
