Running badly at low rpm.
#21
I doubt it's the exup cos if that sticks then you'll get the 7k-0-RPM indication on the tacho.
One thing that has been known to cause similar problems is if something is restricting the air intake. This can be something as silly as an Autocom lead or bit of rag too close to the intake under the seat/tank area. Probably a long shot but as it takes 1 minute to check then worth a look! Hope that helps.
__
There's no replacement for displacement
Ah yes, very true hotmetal, I 'd forgotten about that. In that case I'll check the air intake when I next get the chance. Strangely it's running absolutely fine now, though I know there are a couple of things I need to go over still.
Cheers guys.
