How much alcohol to use in tank?
#21
(18-12-13, 09:21 PM)JZS 600 link Wrote:I had loads in the tank last night but luckily I got the train home
Go Camden!
:rollin :rollin :rollin
Have ridden in zero temps on my fazer without any issue ...., but that was up the grimsell pass in high summer !......snow, ice, blizzard winds...all part of a swiss summer !
yet on another trip, 3 yrs before, it was 25 degrees at same spot. Dont ya just luv the alps ??
My 2002 foxeye carb iced every winter from new to last year when I part exchanged it.
FST Pro sorted it every time and it was no bother, cap full in the tank after every fill up and no more carb icing, preserves the pistons and rings as well apparently.
It was pretty cold this morning and would have iced for sure if I wasn't using this alcohol. It didn't start though I had to bump it :/ I think I may have another issue there...
Check for air leaks then check the valve clearances and balance the carburettors
My mate from Croatia used to bring me lemonade bottles of home made Sliovice  back when he went to see his relatives over there.
150 - 200 mls and you won't give a foc about carb icing anymore
if thats the same stuff we had at work, you can have some great fun with it. pour some over your hand and set it alight. it doesnt burn as it burns so fast. try a small bit first. (dont try this at home kids!!)
