headlight mod
#21
The right side headlight moves about because the adjuster 8mm bolt with cross head doesnt hold against the back'plastic' of the headlight body. It's as if the hole is too big. If i pull the headlight back against the body the headlight works. If i let it go it moves forward and stops working?
(29-10-13, 08:11 PM)apage16 link Wrote:I bought the projector lights and modified my existing headlight unit to accommodate them. There was no real effort for the H4 side. But the H1 side needed a lot of Chopping about! I'll explain it more in my project thread soon.
How easy are they to remove on MOT day?
(01-11-13, 03:06 PM)DanielT link Wrote:[quote author=apage16 link=topic=10470.msg110260#msg110260 date=1383073914]
There's no reason why they should fail MOT. The beam pattern is now tighter than it ever was with a really sharp cut off.
If they did fail,  there's NO way the H1 bulb is going back in!  MASSIVE hole in the reflector! !
