Been for a blast and the front wheel now raises its head :b Gear changes and acceleration allot smoother. Unsure if stutter is still present as I may
have rolled off the throttle when in 3rd but all OK in 2nd. I need to take it on something like a motorway to give it a real test. But first impressions is that all is fine as I is now having some serious fun on the road  ex :lol
Thanks guys :thumbup
Daz 8)
She Ain't Exactly Pretty, She Ain't Exactly Small, Fourt'two Thirt'ninefiftysix
You Could Say She's Got It All.
2nd test ride and all is not as I hoped.
1st gear did not take it up to limit but is OK
2nd gear 10k rmp OK
3rd gear stutter around 10k rpm
4th gear doing 100mph and due to lack of road could not get it to 10k rpm as I was screaming ho shit ho shit ho shit then dropping two gears and whipping it round a roundabout.
Bike runs smoother lower down the rev range but is at its happiest when been ridden hard. Yet when opening the throttle hard from low revs in 3rd gear bike holds back for a second. So I am :think thinking carb balance.
A new noise from the rear wheel is a squeak :groan . Unsure if its the calliper or bearings so I will have a look at that later but only noticed it when going forward.
Daz :wall :wall :wall :wall :wall
Unbalanced carbs makes it jittery at lower speeds, it's worth doing anyway if it hasn't been done for a while, but i doubt it'll be the issue with plenty of throttle?
(11-09-13, 03:51 PM)darrsi link Wrote: Unbalanced carbs makes it jittery at lower speeds, it's worth doing anyway if it hasn't been done for a while, but i doubt it'll be the issue with plenty of throttle?
Yep, carbs need doing but I am stumped at this one darrsi. Thing is it accelerates and rides better but its just this 10k and hard throttle stutter. It does not install confidence for overtaking
Daz
(11-09-13, 04:02 PM)dBfazer600 link Wrote: [quote author=darrsi link=topic=9665.msg100683#msg100683 date=1378911101]
Daz
I had a similar thing when i bought my bike but had a full carb strip down and clean done, and Dyno'd, and it sorted it out.
If you wanna try a quick and easy possible solution, then i would also suggest to you to try the "STP Complete Fuel System Treatment".
Use a half bottle each time over 2 full tanks of fuel and let it do its thing, i personally felt a big difference after a couple of days riding.
It costs about £15 a pop at Halfords.
It's another one of those things that will do more good than harm so i'd certainly give it a go and see if it helps?
(11-09-13, 04:25 PM)darrsi link Wrote: [quote author=dBfazer600 link=topic=9665.msg100688#msg100688 date=1378911737]
Daz
I am going to try this but after I have tested the coils with a meter tomorrow as logic and symptoms are leading to a power leak somewhere in the ignition.
Daz
The multimeter was out and this is how it went.
Both primary coils showed exactly the same reading 2.4
Both secondary coils were different one been 15.90 and other 15.66
[smg id=1185 type=preview align=center caption="day of the multimetre 12 Sep 13"]
So would the secondary coil cause the stutter? No idea :'(
So my next step is to allow this stutter/fault develop as my knowledge of electricals consist of sticking my fingers into the wall sockets for a :eek experience. I will try and find a source to fault find problems specific to FZS600.
Also had the breaks off to make sure they are not steadfast on operation and all is well there. SO I decided to set the load on my front and rear suspension as I is sick and tired of doing zebedee impressions in pot hole central. This one thing has transformed the bike yet again and is a more positive feel of all round comfort.
Not pissed off just getting pissed on the pop
Daz
PS if anyone knows about coils and whether they are buggard let me know as I have no clue what so ever
So tired having to leave notes hear Reds stuttering fzs 600 page 5 to continue reading http://foc-u.co.uk/index.php/topic,2066.100.html
Its war and peace all over again
Daz
So after testing the coil out put I decided to take it out for a run in the Peak. The stutter has now progressed to wider band of any where between 8 - 10k rpm in second gear and above.
My fuel consumption has dropped to 42mpg from 53mpg as an average. So fuel air mix?
With reading reds posts/thread there is a lot to take on and I do not have a garage, tools or space to strip the bike down. Nor do I have the equipment to do the compression tests. Therefore, I need to eliminate those jobs i can do so I can be precise in what I need my friendly mechanic to undertake to keep costs down.
Next I will be going for darrsi suggestion
Daz :\
Before you did the service Daz, how long was it previously that you had run the bike & it was ok???
Just re-read this thread - did you actually try putting the old plugs back in, as it reads as if you found the plug cap problem, replaced those, but didn't actually change the plugs again? Have seen several instances of new plugs being duff. And did you check/trim HT leads?
(14-09-13, 08:51 PM)noggythenog link Wrote: Before you did the service Daz, how long was it previously that you had run the bike & it was ok???
Bought the bike private seller in March from one 88 year old previous owner from new. Last 3 service interval as in book are 2007 at 12305m, 2009 at 16063m and 2012 at 19732m. I assume the services were done correctly.
I bought it with just under 20k on the clock which suggests its been stood more than rode. I have put 4K on the clock since getting it. Minimum outing for me is 80miles a day that is clocked up over weekends.
It fires up every time, apart from service only 2 other major incidents have happened. Bike fell on top of me as the side stand gave way due to me and after service fella helping forgot to turn the petrol tap back on and I came to a stand still.
Stuttering happens with standard and new can it has backfire twice with both cans.
Daz
ye but i mean if the stutter happened after the service then either something you touched or changed did it.....or the service is coincedence....if you rode the bike say 2 days prior to the service & it was all tickety boo then for example it would negate the problem being anything to do with the fuel or the carbs, or lessen the likelyhood anyhow.
but if it was stood for a couple of weeks prior then maybe the service was just coincidence & the real culprit sprung whilst being layed up...
Also the fall is a major event...but was it all fine with no stutter after the fall????....what made you service it, was it after the fall that it was dodgy???
(14-09-13, 09:03 PM)nick crisp link Wrote: Just re-read this thread - did you actually try putting the old plugs back in, as it reads as if you found the plug cap problem, replaced those, but didn't actually change the plugs again? Have seen several instances of new plugs being duff. And did you check/trim HT leads?
[smg id=1187 type=preview align=center caption="Found sat under the Idel speed adjuster screw"]
Yes on all accounts but I am thinking of putting all old plugs and air filter back in. Then testing I did find a piece of rubber sat on the engine that I have been trying to find out where it came from after the service.
Daz
Noggy it was fine after the fall no problems what so ever. It just happened I planned the service before the fall and was awaiting parts and a can became available. Bike was sluggish in comparison to its performance now although everyone who has rode it prior to service said it was a nice ride. Never felt it stuttering but I have only started been snap happy with the throttle.
It has to be something I have or have not done
Daz
I think it must be Daz
re trace your steps & do the service again basically, re fit the old air filter if you still have it & double check the fuel pipe is all good under the tank.I'm a total spoon at mechanics & i did my service & put a k&n in, the bike was totally fine afterwards so i cant say it's something you've done as such but something you've replaced definately.
i cant see how it would make a difference but how much oil did you put in?, worth double checking you havent overfilled.
(14-09-13, 09:39 PM)noggythenog link Wrote: I think it must be Daz
Good call, silly question time but I am questioning everything i have done.
Air filter hole up or down in the box/
Daz
(14-09-13, 09:42 PM)dBfazer600 link Wrote: [quote author=noggythenog link=topic=9665.msg101440#msg101440 date=1379191158]
Daz
Up.
14-09-13, 09:52 PM
(This post was last modified: 14-09-13, 09:53 PM by noggythenog.)
Daz
Oh foc, now that is a question - i think it was Hole Down with the plastic cover showing.but im not sure :rolleyes
but yeah these are the type of things to look at, or is there a bit of packaging still on the filter, or a leaf or bit of rag in the air intake.
with my basic knowledge i defo think it's something to do with this air filter.
edit - shows how much i know, just as well uncle Darrsi's about!
Just gonna indulge in a little thinking aloud here...
Ok, so stutters at 10k rpm in 3rd (for definite, maybe at those revs in other gears but not so noticeable), and also when opening throttle hard at low revs in third. So, electrics are under load in both instances. I can't say anything regarding your multimeter measurements as I don't know what they should be, but, they won't show what is happening when under load. I can't help but thinking that stutters at high revs points to electrical breakdown. Older bikes do tend to have such breakdowns more than newer bikes - just materials degrading over time - mileage not necessarily the most important factor.
Still, easiest and cheapest things first, and if that means air/fuel systems, so be it.
