Poll: how often do you clutchless gearchange ?
You do not have permission to vote in this poll.
never
13.64%
6 13.64%
occasionally
38.64%
17 38.64%
trackdays
0%
0 0%
regularly
34.09%
15 34.09%
all the time
13.64%
6 13.64%
Eh ?
0%
0 0%
Total 44 vote(s) 100%
* You voted for this item. [Show Results]
clutchless gear change
#21
You mean some folks don't?
Clutch is for 1st gear, sometimes 2nd to 3rd in traffic, and on it down changes only.
I guess it's like lots of folks don't know how to steer their bike (true but frightening) and loads of folks are fathing aboot screwing up gear changes with the clutch when you don't need to touch it.  Dear of dear!
...on the topic of "smooth" changes, how about "blipping" on downshifts?  I've tried it a few times but can never get it right, I'm sure the missus would appreciate it though.
Eagles may soar, but weasels don't get sucked into jet engines...
(08-07-13, 09:01 AM)Buzz link Wrote: ...on the topic of "smooth" changes, how about "blipping" on downshifts?  I've tried it a few times but can never get it right, I'm sure the missus would appreciate it though.
Practice until you get it right. Small 4 cylinder Fazer is forgiving, but a single cylinder bike could lock the rear wheel when downshifting without blipping (unless smooth with clutch).
Yup, I do this all the time as well Smile
Took a bit of getting used to initially, but I do it without thinking now. Occasionally I'll get it wrong a little, but most of the time its fine and is sooo much smoother when coming down the gears
Tried it once, didn't like it..... ( Bit like sex  Big Grin )  Mate of mines a retired bike copper, does it all the time. Been a pillion on his bike and it was as smooth as you like. Not for me though, just can;t get the knack so I stick with the clutch. Horses for courses I think.
If you want to give God a good laugh, tell him your plans.
For less experienced riders having the clutch is a good start! Clutchless changes can be done smoothly quickly & without any internal engine damage-but as they say "Practice makes Perfect". It also helps if you can visualise what all the various components are doing inside the motor/gearbox-encourages mechanical sympathy. No reason why you cant learn to front brake & downchange blipping the throttle simultaneously.
Its quite a good feeling when you master it, using the front brake at the same time takes a bit of getting used to. I understand why a lot of riders only use one or two fingers for braking now and why they fit shortened levers... definitely on my to-do list Big Grin
Had to do 200 miles without a clutch when my beemer broke down in wales - clutchless changes are easy just get the revs right and gently apply pressure on the lever till it snicks in -  its the stopping/starting without one thats the challenge!
However my preference is to use the clutch as Mr Bike Designer intended.
(10-07-13, 08:51 AM)notoriusb.e.n link Wrote: Had to do 200 miles without a clutch when my beemer broke down in wales - clutchless changes are easy just get the revs right and gently apply pressure on the lever till it snicks in -  its the stopping/starting without one thats the challenge!
I thought you were supposed to roll off the throttle while changing so that the gears are not under engine load ?
Yes, you want the revs to be about where they would be for a normal change (or slightly higher) and let off, then re-engage. tbh though I was a bit caveman in my approach being as it was out of necessity rather than choice.
(10-07-13, 08:54 AM)simonm link Wrote: [quote author=notoriusb.e.n link=topic=8708.msg86812#msg86812 date=1373442674]
Yup, that's correct Smile
Completely different technique required when coming down the box and its much more difficult
the answer to a smooth clutchless gearchange up and down the box is to match engine speed to road speed  Wink  this is why blipping helps on down shifts.....try it going down the box by very gently pressing down on the lever whilst the revs drop on slowing down and when the speeds are matched it will just slip into gear....thats why practice helps and also getting to know the bike  Big Grin
have a look at this.....
https://www.youtube.com/watch?v=PdrUj1Kq...20&index=6
Useful little vid. Maybe I'll have another go Big Grin
he has done a better one.
will see if i can find it.
(10-07-13, 01:46 PM)sure2ride link Wrote: Useful little vid. Maybe I'll have another go Big Grin
I found it virtually impossible until I had correctly adjusted my gear selector.  Just a light pressure upward on the gear selector,roll off the throttle, the gear will slip in and then on the throttle again.  It's a sweet feelin
(10-07-13, 02:38 PM)simonm link Wrote: [quote author=sure2ride link=topic=8708.msg86865#msg86865 date=1373460362]
sure is !
have found a false neutral a couple of times though which is a bit embarrasing!  :o
(10-07-13, 02:43 PM)Enceladus link Wrote: [quote author=simonm link=topic=8708.msg86880#msg86880 date=1373463501]
sure is !
I've found myself using the clutch for 1-2 cos it's so clunky I only really clutchless going upward for 3,4,5 &6
(10-07-13, 02:54 PM)simonm link Wrote: [quote author=Enceladus link=topic=8708.msg86881#msg86881 date=1373463822]
sure is !
ditto.
if you have a look at the other gearchanging vids russ (roadcraft nottingham) has done, they are quite helpful as a prelude to clutchless changing.
sure is !
Just in case; a false neutral is finding a space between two gears (that aren't 1st or 2nd) where neither is engaged
I've had this happen once on my old bike where I went to go from 5th to 6th and ended up not being in any gear at all, makes a nice crunch when you finally get it in Tongue
