08-05-13, 09:12 AM
(This post was last modified: 08-05-13, 09:36 AM by OutofFaze.)
Hi again,
It is more of a feeling than a noise to be honest... Last time it happened, I tried to listen for it bit realised I could only hear wind noise in my helmet.
Also, I studied it more and can feel it in the handlebars like I already said, but also feel it in the pegs and the seat. It feels like the engine just starts making more friction at 6k rpm. Also, I definitely found that speed doesn't matter, it is only the revs, because I can feel it in several gears at those revs. 5.5k and down, 6.5k and up feel smooth all the way.
Also, if I am say at 7k and I lift off the throttle slightly so that the revs drop to 6k I think it can feel more pronounced than if I rise up to 6k. I found that very weird.
I'm an acoustic engineer and I had a weird thought that maybe it is something to do with the air intake. It is very possible that the engine draws air at such a speed (at 6k revs) that it corresponds to the resonant frequency of the intake pipe and makes a really weird sensation. Something like a Helmholtz resonance (like when you blow across a half empty bottle and it sounds like a lighthouse, then you can feel the bottle vibrate)... It feels like that sort of thing but because I can't hear anything for the wind noise in the helmet, I can't really confirm. An acoustic resonance would correspond to the gradual build up and tail off at lower and higher revs than 6k... And also the preciseness of the problem.
Also at lower speeds when I can hear more through the helmet, there is a strong sucking sound from the air intakes so I will check if perhaps something is obstructing it in some way, or just normal behavior.
I've checked everything mechanical I can on the bike:
-Wheel bearings (Front and back)
-Chain tension and alignment
-Engine oil level
-Brakes don't stick at all (as far as I can tell from checking the pads and moving the wheels while on the center stand)
There is a rattle in the fairing exactly as described by the headlight but that occurs at other revs and I just pressed the fairing as suggested by the left headlight and it went away... So I'm not worried about that.
I haven't noticed any lag in power because of this though... Just the feeling.. So I dont think that anything is being degraded or broken.
Maybe I'm just too particular, and I guess I could have written a book about these sorts of things with my old XT600E hahaha :-)
Once again I appreciate your help and suggestions guys! Many thanks :-)
James
Smokey this is not 'Nam, this is bowling, there are rules!
08-05-13, 09:31 AM
(This post was last modified: 08-05-13, 09:34 AM by xlewisbdx.)
Try the front sprocket nut? Fazers have common problems with them.
Well that sounds less worrying at least  May be worth checking the Air Filter as you suggest to see what sort of condition it is in or maybe even look at the plastic panels around the air box - if it is the air intake causing the noise these could be vibrating a little against the frame though they should be secured against rubber fittings.
I think Limax's opinion, that this is just the standard "rough zone" the Fazer has, is probably the correct one. The engine mass combined with the rubber mounts has a resonant frequency, and when the reciprocating parts hit that range you do feel more of a buzz though the footpegs and bars.
The solution, of course, is to spend as much time as possible above 7000rpm. :b
A blocked air filter could create a noise if it's not getting enough air but that would also be felt in performance as well.
How old is the filter?
Next time you change it swap it for a K&N.
08-05-13, 12:20 PM
(This post was last modified: 08-05-13, 12:24 PM by OutofFaze.)
Hi guys,
I'll certainly check the air filter element. Had a look in the manual and it looks very easy to check. I will also remove it completely and reassemble the tank and seat, then run it 1km down the road and back to see if the 6K thing changes (it will be different with more flow if my air/acoustic theory has any truth in it)... then i'll put the filter back in before I cane the engine completely. I was thinking of getting a K&N filter for the bike, but does anyone know if that makes it TOO lean then?
Also, like Limax and Razerider said, it could also just be the "rough" zone... and if my carbs are a little out of balance then it could *enhance* the feature
Anyway, i'm glad that nothing serious seems to be wrong and at least it prompted me to really go over the bike so i have a good idea of the state of everything now, other than just the shiny and newly polished looks!
**by the way... there is a high possibility that all my worrying is a result of becoming too attached to a newly purchased bike  I called it "Francesca" FFS because of FZS 600... lame right?!**
James
The Fazer runs rich as stock so the K&N helps balance this out a bit so there is no danger of it running too lean. The majority of us have a K&N air filter and with an market exhaust and/or downpipes and have no issues
Yeah, K&N all the way, not heard one complaint on here, all positive reviews
"....**by the way... there is a high possibility that all my worrying is a result of becoming too attached to a newly purchased bike [img alt= ]http://foc-u.co.uk/Smileys/efocicon/cheesy.gif[/img] I called it "Francesca" FFS because of FZS 600... lame right?!**...."
Yep :lol
I get the exact same symptoms on my 2000 600. I'd put it down the the harmonics at that rev range. Isn't that roughly where the flat spot in power is?
Yeah I would say so. It doesn't feel like no power, just less. But then the power band kicks in after that too.
At least I learnt something :-)
James
Hi again guys,
I still have this problem. I thought that it had got better, but it's still there even though some days feel better than others.
One really important observation that I made today is that the grinding feeling stops completely when i pull the clutch in when I am at the "grinding rev range" which is from about 5,500rpm to about 6500rpm occasionally a bit higher, into 7000rpm.
So, this is something that I don't really get... I don't think it is something from the chain now because it's adjusted well, lubed properly and still turns when the clutch is in because the wheel is moving. Could it be out of balance carbs? I thought that would make the tickover lumpy though, but that is smooth. I also don't think it is the air intake either now because it definitely feels mechanical. I spent almost an hour on a ride today observing this.
I'm thinking about taking it back to the Yamaha dealer again and insisting that they take a good look at it (they said that I could if I feel that it gets worse, or doesn't get better), because i'm not happy about it staying like this.
Any more ideas fellow Fazers?
James
no grinding noise but mines the same between 5 & 6.5K, have looked it up and it seem like character more than anything else, sometime disappears completly tho, but looks like a knackered engine mount isnt helping
If it stops with the clutch then that's the first thing I'd take a look at personally. You can do this without removing the engine oil as well - just put the bike on the SIDE STAND (important otherwise you will lose your oil  ) then remove the clutch cover and undo the 6 screws that hold the clutch springs. You can then inspect the clutch plates to see if they are worn. Should only take 10-20 mins max and it will rule it out if it isn't the case
The gasket should be re-usable but they aren't expensive if you feel like replacing it anyway and do not tighten the spring nuts up overly tight! I accidentally did this and it snapped the housing  They only need to be done up to 10Nm which is basically hand tight with a spanner
Sorry to bump an old thread but did you get any further with your vibration, I recently bought a 98 FZS600 which has exactly the same vibs, comes in at 6k and is gone by 7.7k, regardless of which gear or speed, also notice a def drop in power, it pulls really well upto 6k then goes flat and streaks away after 7.5k , I am happy to live with it but would be even happier if I could get rid of it, my bike has done 28k miles,
Old enough to know better
Hi Fraser,
Sorry I didn't update this thread with the outcome.
I took the bike back to the Yamaha Center that sold it to me, and they kept it for a week and lent me an FZ-1N for the duration. So, they took it on 3 test rides, 1 was the owner of the shop, and 2 with the chief mechanic.
They couldn't find anything that they considered to be out of the ordinary with the bike, but they still checked everything that they could do:
- Tightened all the engine mounting bolts
- Checked the brake pads and discs
- Front wheel bearings
- Drivetrain
He told me that every bike has it's own special feeling and sounds, and to just live with it and get used to it. however, when it came back, it did feel a lot less pronounced to me. Perhaps something to do with the engine mounting bolts were a little loose or something. Anyway, it doesn't bother me anymore. I just try to stay on either side of that rev range.
I also read here: http://www.visordown.com/road-tests-used...313-2.html
Page 2 (under engine) says: "One of the few bug-bears is a vibration at anything between 6-8000 revs. They all do that, Sir."
So it seems that this is normal behaviour. The problem I had is that I've only ridden an XT600e which is only single cylinder and feels entirely different. I'd had no experience of a 4 cylinder bike until that point, so i didn't know what to expect. Anyway, i've got used to it now and it feels really sweet otherwise.
James
thanks for the quick reply, I've had loads of bikes and they all are slightly different, I was just a bit concerned that there may have been a problem inside my engine waiting to go bang LOL, I'm going to stop worrying about it , Fraser
Try checking all your engine bolts... that seems like the most useful thing to me.
With mine, I would estimate that after getting it back from the shop, the vibration has reduced by about 50%+ at the worst times (normally after over an hour of riding). Also, if the chain is too tight, it could make things feel crappy because it loads the front gear with a pulling force against the shaft and of course reduce the chain life drastically.
My theory is that 6-8K revs is just the resonant frequency of the engine, where everything just starts to thrum at it's natural vibrating frequency. It's the same thing as when you sit on an old diesel bus and it wants to shake itself to pieces when it's ticking over at the traffic lights. In that case, the bus engine tick over frequency matches the resonant frequency of the bodywork and frame of the bus... and voila you are suddenly sat inside a threshing machine.
On a side note, I dropped a K&N air filter in mine when I got it back and I can't honestly say if it feels more powerful, but it definitely doesn't feel less powerful and I have a lifetime air filter and got to whack a sticker on the bike and one on my helmet to cover a little bit of damage from when I dropped the helmet from handlebar height to the floor.  it's good enough for now!
I've only skimmed through the thread so it might have been suggested already but the exhaust on my bike resonates at 6000rpm so I'd say yours is probably doing the same
Hi, guys!
Sorry for bringing up this again- FZS 600 vibration at 5.5-6.5k rpm. Has anyone found a solution to this vibration? It is bothering me a lot.
