Ticking before I start the bike.
#21
(19-03-13, 02:05 PM)darrsi link Wrote: [quote author=packie link=topic=6814.msg64253#msg64253 date=1363694773]
btw Alex...as you can gather, the noise is normal. Even leaving it sit overnight or for a few hours, the fuel pump "tops" up the carbs. That's the sound of the fuel pump in action. How long the noise lasts is dependant on how much the carbs need to be topped out. When I switch on the ignition, I wait a sec until its done its thing. Then I proceed to start. Sometimes you can get a slight hesitation in starting until its done its thing.
Cheers.........
Who's Alex?  :lol
LOL....no wonder he ignorned me!!
Thanks for pointing my mistake out, John.
(19-03-13, 03:59 PM)packie link Wrote: [quote author=darrsi link=topic=6814.msg64269#msg64269 date=1363698318]
Cheers.........
Who's Alex?  :lol
Are you calling me John now, or is that you?  :rollin
Reminds me of Will Smith......  Tick, tick BOOM.
(19-03-13, 01:06 PM)packie link Wrote: btw Alex...as you can gather, the noise is normal. Even leaving it sit overnight or for a few hours, the fuel pump "tops" up the carbs. That's the sound of the fuel pump in action. How long the noise lasts is dependant on how much the carbs need to be topped out. When I switch on the ignition, I wait a sec until its done its thing. Then I proceed to start. Sometimes you can get a slight hesitation in starting until its done its thing.
Cheers.........
The names Lewis but thanks for the help Wink
(19-03-13, 08:01 AM)simonm link Wrote: I'm a newb, only got my license in Jan and am a little over the hill to start riding a bike at 36 but pretty much all of your youtube bids had me cacking myself.
I passed my test last year - after my 40th...I'm too old to slow down now  Wink
[Image: 161084.png]
You said it speeds up? Oh dear. That's not the fuel pump.
A friend of mine had that on his bike, ignored. Next thing he knew, the bike blew up. The ignition sends a high current pulse of voltage through the full system as a self diagnostic. The ticking you heard is a danger sign.
What isn't publicised (it's pretty rare) is that all fuel sensors have a nasty fault which means they can fail castastrophically. The ticking is the first symptom is the ticking. The fuel pump and fuel sensor are on similar circuits, and the pump runs BACKWARDS for a tad. This can mess up the fuel sensor. If you're riding, and it seems like the fuel indicator is jumping around abnormally, bail out! It means the sensor is about to fail completely, and fall out of the tank, dumping petrol onto the cylinder block, and the airbox. And if the adiabatic atmospheric sensor is faulty - boom.
You have been warned.
The Deef's apprentice
(25-03-13, 12:02 AM)ChristoT link Wrote: ... adiabatic...
Ooooh!  Good word!  :rollin
[Image: 161084.png]
(25-03-13, 12:02 AM)ChristoT link Wrote: You said it speeds up? Oh dear. That's not the fuel pump.
Are pulling our legs? This seems incredibly unlikely. Can you provide some evidence to back up your statement?
This link explains it a lot better than I ever could. :lol :lol :lol
http://hyperphysics.phy-astr.gsu.edu/hba...adiab.html
Biking is about the Journey NOT the Destination...
(25-03-13, 11:00 AM)John Silva link Wrote: This link explains it a lot better than I ever could. :lol :lol :lol
Maybe it's just me but a formula explaining no heat is gained or lost in a system doesn't explain why a fuel sender would be an explosion risk, or why this wouldn't have been figured in the design of the system, why google shows nothing I can find on fuel sender explosions.
Like I say, must just be me.  I did find this interesting link though http://forums.iboats.com/non-repair-outb...10584.html.  I see no reason why a fuel sender in a car would be any different to a fuel sender in a Bike from a danger perspective (they perform the same function in the same way).
This is a good one too:
http://www.theminiforum.co.uk/forums/top...-question/
I also don't understand why a sensor failing would result in it falling out of the fuel tank.
Please forgive me, I'm a critic.
I think it might be a wind up Wink
My fuel indicator does go abnormally sensitive at times. But I've accounted that for some kind of resistor heating issue, since it only does it occasionally during long rides. I've taken the fuel level sensor out of the tank and had a look at it, but it's a pretty simple and sound piece of engineering. Mine didn't have any mechanical or electrical component failures that I could see. Plus when I changed the original lights of the dashboard to LED lights, the malfunction has become increasingly rarer, warranting me to believe that there really are resistors on the circuit board before the dial, which may heat up and hence change resistance.
How can the sensor fail completely and just fall out? It's a pretty tight squeeze to even get it in. I will however acknowledge that the o-rings on the cover may fail, but that still wouldn't amount to full catastrophe. You'd easily smell the leak, before it got so bad that it would ignite.
And what is an adiabatic atmospheric sensor? Never heard of that.
(25-03-13, 11:46 AM)Lawrence link Wrote: I think it might be a wind up Wink
ha ha.  Hilarious.  :rolleyes :'(
:evil :lol
