The sprocket fix is still holding after 2100 miles,
which included some lively miles playing with a fellow on a s1000rr after a losing a R1 on the coast roads near home. The s1000rr rider was shocked when he realised he was trying to stay with a 600, when I stopped at a busy cross roads,
This was the conversation
S1000rr rider “Didn’t realise those Fazer 1000s were that quick" My reply "Its a 600" silence and then he says "Jesus you must be ringing its neck" :rollin We had a great time for the next 15 miles.
Anyway back to my issues with Yamaha Ireland (Danfay) I took them up on the offer after trying but failing to get them, first to give me the parts at half cost price and then tried for half the trade price. I gave up my haggling when I was asked if I was going to take the offer or not. I suppose after 73000 miles I was lucky to get what I got.
This is the list of parts I ordered:
Quantity Part number Part name
1 5DM-11181-00 GASKET, CYLINDER HEAD
1 5DM-11351-00 GASKET, CYLINDER
1 4HM-12213-00 GASKET, TENSIONER CASE
4 90430-10188 GASKET - OIL DELIVERY PIPE
4 3YF-14613-01 GASKET, EXHAUST PIPE
1 93210-12152 O-RING – CRANKCASE
1 90430-06166 GASKET – CRANKCASE
1 93210-06422 O-RING – CRANKCASE
1 4TV-15461-00 GASKET, CRANKCASE COVER
1 4TV-15462-00 GASKET, CRANKCASE COVER
1 93210-48364 O-RING – CLUTCH
1 4TV-17421-00 AXLE, DRIVE
1 93440-30077 CIRCLIP - AXEL DRIVE
1 93102-35368 OIL SEAL - AXEL DRIVE
1 90891-10124 SPROCKET NUT, WASHER, KIT
1 4JH-16340-00 PUSH LEVER ASSY
1 4YR-15427-00 COVER CAP
1 90890-85508-00 TUBE YAMAHA BOND 1215
I have the parts now, but will not do anything unless my fix fails. Interestingly I measured the threads on the new shaft and they measured 17.80mm. I found the measurements I took when my sprocket fell off originally and it was 17.35mm
which included some lively miles playing with a fellow on a s1000rr after a losing a R1 on the coast roads near home. The s1000rr rider was shocked when he realised he was trying to stay with a 600, when I stopped at a busy cross roads, This was the conversation
