If I recall correctly the kit in the link requires the removal of the spigots from the cylinder head which is not an easy job. I can reccomend the holeshot kit but you'll pay as much for postage from the states as you will for the kit, unless a group buy can be arranged.
		those that have tapped theirs and used a screw i was thinking of tapping mine and cutting the siggots flush to the head,will this work or will there be problems?
		I think you need to explain your idea a bit more, it doesn't sound logical to tap the spigots then cut them off, as mentioned it is possible though allegedly difficult to remove them at which point the kit on ebay would potentially be a neater and simpler idea. Out of interest how are you planning on cutting them?
		In all honesty I only ever see the stubs when I'm on the floor cleaning my bike so looks are not much of an issue, I don't think what you're contemplating is practical but then I still don't understand what you're planning. You could get some domed allen bolts which look neater than a hex headed ones.
		Don't cut, just tap.
Make sure you have a good quality taper tap.
		those of you that are going the diy route with a tap i bought a m8 taper tap from a local tool supplier made by lyndon,the square end on the tap is 1/4" and a brake adjuster spanner is an ideal fit (mine is a double ended square ring spanner) so hopefully i should have no issues threading the spiggots when i come to tapping them
		Good luck with it. I have just done another one yesterday & I will say it again, it's a pain in the ass of a job. 2 & 3, piece of cake, takes minutes but 1 & 4.. .    :'(
