Fed up with stainless pipes not lining up right with rear can so took them off cut at a joint & rewelded them I will post up finished pics tomoz
Stuff everything I've always got my bike Smile
(05-10-16, 11:48 PM)bikemad link Wrote: Fed up with stainless pipes not lining up right with rear can so took them off cut at a joint & rewelded them I will post up finished pics tomoz
You see this is why I keep painting and filling little holes in my black 18 year OEM ones, issues with alignment, bore size, balancing tubes, is there any that will just be a straight swap
I think issues are caused by the heat from welding process distorting the tubes so although they are jigged they spring back when taken out to cool off,I had simlar issues with an XT600 front pipes got partial refund from seller luckily I've got tools to do the job myself Smile
progressing slowly with the silver fazer 600 replaced the carb to engine rubbers today the old 1's were badly cracked next job is the wheels do i keep the gold 1's back wheel has some chips in it so might put my spare set of tidy black wheels on not decided yet.
All done & lots of clearance from swingarm couldn't ride my bike yet though it started raining plus forecast not great sat daytime either Sad
.jpeg   image.jpeg (Size: 111.56 KB / Downloads: 100)
.jpeg   image.jpeg (Size: 69.15 KB / Downloads: 97)
Fitted my renthals bars , it was ok but a bit og a chew on getting everything off
liking them
(04-10-16, 10:13 AM)fazersharp link Wrote: [quote author=darrsi link=topic=17296.msg243030#msg243030 date=1475562935]
Was a hard slog but i renewed and refitted a gear lever rubber.  Confusedmash
I need a new one of those and the local stealer wanted £7+VAT
Gonna cost me more than that now anyway, the one i bought totally does the job but has a brand new outer diameter of 16mm, which is less than the OEM one.
Saying that, half my OEM one looked chewed to bits anyway so it doesn't really matter, but i just fancied it a tad bigger if possible.
I couldn't find the damn thing at all on the AJ Sutton site, but after a bit of research it turns out that the very large majority of gear levers use the same standard fitting measurements of 8mm inner diameter and 40mm length, so i ordered this one which i'll get in the next couple of days.
http://www.ebay.co.uk/itm/191962379408
(14-09-16, 10:49 PM)gicut58 link Wrote: Bought and fitted (well, got the engineers to fit...) a cheapo top box onto my Renntec rack.
This one:
https://www.amazon.co.uk/Ryde-Carbon-Eff...111SNDJYX5
about £35 all in, seems ok, time will tell, good so far, does what it says on the tin.
My top box overtook me one day as i slowed down near my work going through a 6' 6" width restriction.
Renntec racks have a manufacturers recommended weight limit of 2.5kg believe it or not, and i think the fact i use 2 roads daily with speed bumps to and from work took it's toll and the rack just snapped clean in half.
2.5kg does sound like feck all but i s'pose they do their own tests and come up with a safe upper limit to cover themselves.
(09-10-16, 07:36 AM)darrsi link Wrote: [quote author=fazersharp link=topic=17296.msg243039#msg243039 date=1475572425]
Yes I looked into it a couple of years ago as mine is chewed up and came to the conclusion that most are a standard fit, but that ebay one I think is round but I think I am right in saying that the oem one is oval.
I wil let you pay for the ebay one and then await your in depth report with pictures and fitting instructions
Mainly been stripping, cleaning and regreasing the rear shock linkage assembly  Smile
Better to have it and not need it than to need it and not have it...
(09-10-16, 12:31 PM)fazersharp link Wrote: [quote author=darrsi link=topic=17296.msg243373#msg243373 date=1475994967]
You won't notice the difference whether it's round or oval, but i did notice the slightly smaller diameter on my toe.
I'm almost certain the 20mm one will be better, for me anyway.
Finished off my front end conversion this weekend (well I say finished. ....finished for now lol)
[Image: 20161007_215933_zps3jafeon4.jpg]
[Image: 20161008_082856_zpso1nyveb9.jpg]
Might not be to every body's taste but I think it looks good
(09-10-16, 06:12 PM)darrsi link Wrote: [quote author=fazersharp link=topic=17296.msg243393#msg243393 date=1476012686]
I can't believe i just looked at the gear lever rubber i fitted the other day and it was already disintegrating at the end!
The other one has just arrived and not only does it look much more like the OEM size, albeit round in shape, the material used is much harder than the other one.
It wasn't gonna go on cold, so i put it in a cup of hot water for a couple of minutes then it pushed on straight away.
It can only be better than the first one, but i'll let you know if it also fails miserably, although i doubt it will.
removed damaged fairing and got busy with the hacksaw and sander, removed all the damaged parts and cut down the screen, altered the renthal's so they are more forward. just need to sort out mirrors and cut down the fairing infills. rad guard needs spraying black/graphite and thinking about cam covers too.
what ya reckon? doesnt look too bad in my opinion and i'm happy with it. it still offers good wind protection and the renthals are a must as I have so much wrist damage that standard bars just hurt me.
cheapy chinese exhaust still going strong, not bad for £40 eh? the finish is as good as when i bought it, no flacking etc and rivets holding strong.
my momma always says, stupid is as stupid does.
that's all i gotta say about that
Turned my bike into a bit of art.
.jpg   IMG_20161011_183150_processed-1.jpg (Size: 631.25 KB / Downloads: 235)
Just finished fitting and testing my new leavers, they are a bit shorter than I thought they were going to be but they work so much better than the original OEM ones.
RIP my beautiful red beast 1999 to 2017 ???
(13-10-16, 07:23 PM)Fazer99 link Wrote: Just finished fitting and testing my new leavers, they are a bit shorter than I thought they were going to be but they work so much better than the original OEM ones.
Been using similar levers for a while,  good old fleabay aye Wink  much better feel with the shortys and good quality [Image: d0bc320a996d87aeb0b1f15d7943406e.jpg]
Sent from my SM-G935F using Tapatalk
Set Fazer's to stun
(13-10-16, 10:04 PM)matt7chunk link Wrote: [quote author=Fazer99 link=topic=17296.msg243723#msg243723 date=1476383028]
They're surprisingly good quality considering they only cost me £15 for the pair.
Next jobs to do are fit my new mirrors when they arrive then I need to find some time to fit my new Afam chain and sprocket set and finally fit my uncracked inlet manifold connecting rubbers which have been sat on the workbench for a couple of months now.
update so far on my fazer 600 replaced x4 carb rubbers removed stickers of the front forks and give them a bit of a polish removed the gold wheels and fitted my spare set of black wheels all cleaned up do's look better with the black wheels, silver body work the gold wheels would look better on black or burgundy fazer just the belly pan to sort out and a good clean.
[Image: STA60015_zpsiicbip1s.jpg]
[Image: STA60014_zpsuogcxq1m.jpg]
