[Image: 4387467_460s.jpg]
To Poland!
not today,but last night  went to a very hot and sunny weston bike night in wsm,bumped into bristol banger and devilsyam briefly. 8)
not sure fazers were built for off roading tho.....
Cleaned it after going to seaside yesterday after tea.[Image: u4apaget.jpg]
I painted me forks Big Grin
What did you use to paint them?
Rattle can paint, primer, aluminium colour and clear coat. Looooaaads of layers.
They were really corroded, took 4 hours just to get that sorted.
Looks really smart!
What did you use for the fairing in-fills just above the radiator?
Chris
[Image: 208008.png]
(13-06-14, 11:24 PM)Chris link Wrote: Looks really smart!
Chris
They always ask that, eh TGB?  :lol :lol
His is a very rare variant made for riding schools, hence the different clocks and naked as standard. The infill panels ar factory standard!
The Deef's apprentice
Thanks Chris and yes as Christo says, they're standard. (Thanks Christo)  :lol
oh right, never heard of that variant before. looks good.  8)
Chris
[Image: 208008.png]
Cleaned months of accumulated chain lube and gunk away from around the front sprocket cover, stands and pivots, and anywhere else I could get at without having to remove anything. Found the perfect brush for doing it knocking around in the garage, so there ARE useful things in there too!  :rolleyes Happiness is a good cleaning brush  :lol
Then gave it a thorough wash down - about 2 hours in all; now that'll have to do til this time next year...
Bought choke cable and fairin infill's from b1k3rdude (and drank his shite coffee) then taxed it and ordered levers and barends from ebay so soon I'll have all i need when i nip up to deefer's to get it all sorted.
Adjusted head stock and chain. Serviced EXUP. Checked tyre pressures and fliud levels. Put the db killers back in the pipe, then took it out again.  :lol
(14-06-14, 05:43 PM)Kosmic Kartman link Wrote: Adjusted head stock and chain. Serviced EXUP. Checked tyre pressures and fliud levels. Put the db killers back in the pipe, then took it out again.  :lol
Oh shit, yeah. Tyre pressures. Thanks for the reminder!
finally got a chain guard (off BBB - cheers Smile ), fitted and ready to.....guard..?
As usual when fitting new bits to a bike it shows up the rest of it... must clean more.
[Image: 14440930763_b924f2cd7b_c.jpg]
Intentionally left blank
Carbs cleaned out, tomorrow, they go back on, along with the rear wheel.
Getting there.  Smile
Just got back from 170 miles round trip to a race meeting on Anglesey. Lovely weather, good racing. Only downside, one rider airlifted to hospital after an off. Thirty riders on the grid for some races. Another day of racing tomorrow, spectating I must add.
Went to Largs, exup focced again
(14-06-14, 07:14 PM)bigbluebear link Wrote: Went to Largs, exup focced again
What is wrong with it?
[Image: 20140614_155935_zpswvepsynn.jpg]
[Image: 20140614_160420_zpsmxjlddov.jpg]
[Image: 20140614_161548_zps7ytcnycd.jpg]
Stripped the head bearing down to re-grease and torque to the spec as provided by Haynes and in doing so discovered the Right hand (as you sit on the bike) lower triple clamp was not tight - I have now torqued all bolts in this area and in doing so have removed the slight click/ Knock I had.
Also decided to adjust the play in the clutch cable for my liking the cable had been over adjusted at the level. So it set about adjusting the 12mm bolt and screw to find I made the clutch slip Sad all sorted now after realising I had not held the screw as I did up the lock nut.
Users browsing this thread: 29 Guest(s)
