Just about finishing off my mirror blanks for the gen II. Tried a few different methods, gonna spray them up and post the results on here for all to see.
Also been having mad thoughts about chopping the front fairing sides off and making her look a bit like an Aprilia tuono .
(Anyone got a busted up one I can practice on)
[Image: 850481.png]
Had a ride from Leeds/Hawes/Sedburgh/Settle/Leeds. Saw a few Fazers but not in enough time to give the salute!! Twisty roads.
Still testing the 1000 shock on my 600 that may need tweaking still, but not sure what to do. Front brakes seem to be getting worse so need
some TLC and need some new discs anyway.
260 miles following the route of tour de France from York to Skipton aysgarth hawes over buttertubs pass to reeth leyburn and Ripon then home to Yorkshire coast.
(05-05-14, 08:47 PM)dickturpin link Wrote: 260 miles following the route of tour de France from York to Skipton aysgarth hawes over buttertubs pass to reeth leyburn and Ripon then home to Yorkshire coast.
I went to Aysgarth falls once, it was beautiful.
Little spin - 150ish miles saw Laugharne - Fishguard Harbour - Owls Nest Llandovery - Home
(05-05-14, 09:16 PM)MarkWales link Wrote: Little spin - 150ish miles saw Laugharne - Fishguard Harbour - Owls Nest Llandovery - Home
Ah i coulda met you on that run mate...mind you still niceto get out on your own too...i went Carew, Pembroke, Angle......returned & then went over the Presselis for good measure...i also went to fishguard yesterday...sounds like fishguard sees its fair share of fazers.
So whats this "owls nest" Landovery
(05-05-14, 09:14 PM)noggythenog link Wrote: [quote author=dickturpin link=topic=6412.msg146606#msg146606 date=1399319252]
Aysgarth Falls was where Robin Hood (with Kevin Costner) was filmed fighting in the waterfall...lovely spot.
(05-05-14, 09:57 PM)slimwilly link Wrote: [quote author=MarkWales link=topic=6412.msg146621#msg146621 date=1399320998]
Its a Tea Room / Cafe slightly further on than the West End Cafe - I prefer Owls Nest
Even I managed to get a day ..well afternoon pass from the wife. I took a nice ride from Hull to Wetwang, Stamford Bridge, York, Malton, Staxton, Foxholes, Sledmere, Fridaythorpe, back to Wetwang and home about 120 miles. Bike seems to be covered in flys so a good excuse for a polish.
Recieved my SMD Driving lamps
failed the MOT as the horn was not working (was working sunday)
rewired the earth cable as this had a break. Now passed.
Previous owner wired car horns and used the thinnest speak cable to wire it. [size=78%]Ill rewire it all at the weekend properly Sad[/size]
[Image: 20140507_173348_zpsfadkeyw8.jpg]
fitted Ebay SMD DRLĀ  Big Grin
Foccin ell Mark i wont miss you now mate.
You need the double headlight mod now though.
yes I do need the headlight mod
My MOT tester warned me I could damage the electrics by doing the dual headlamp mod
(07-05-14, 07:07 PM)MarkWales link Wrote: yes I do need the headlight mod
I dont think it does though mark....but when i got my crappy headlight fitted the guy said eh it looks like you had the headlight mod and now both lights come on but dont use it unless you really have to as it might get so hot it will melt the wiring........sounds kinda similar to what you got told.
However loads o folk on here do the mod & have no dramas.......well they do have dramas.....not with the lights though. :rolleyes
I must admit riding it to a dealers to test a MT09
The tester is incorrect if the modification is done correctly because the on/off switch is only ever switching on or off 2 bulbs maximum like it does without the modification.
However he is correct if the modification is done incorrectly
Without the modification Headlight on the right and dim on the left are on together when switched to Hi and the left dim is on when switched to Lo
With the correct modification the left and right dims are on together when switched to Lo and the headlight on the right and left dim are on when switched to Hi.
If both dims are on the combined wattage is 110watts (2 *55watts dims)
If Headlight and dim are on the combined wattage is 115watts (60watt head and 55watt dim)
Many modified the light incorrectly and ended up with both filaments of the H4 bulb on at the same together and this caused overheating of the bulb and wiring as you had 60w+55+55=170watts being powered via the on/off switch
The correct modification is done by connecting the spare green wire in the left hand switch to the spare connector on the H4 bulb. Follow the wiring from the left hand switch group to the block connector in the electrical box under the tank. You will see one of the connector blocks which has a green wire going in on one side and nothing coming out of the other side. The is the wire you require to connect to the spare connection on the H4 bulb.
Unfortunately I have no pictures to show you so I hope this makes senseĀ  Smile
Well i did 100 miles bout the pembrokeshire coast.
Was quite nice.
Nice to see the Noggyfighter still out and about
Users browsing this thread: 63 Guest(s)
