Cheapest cartridge emulators, Debrix no more? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Cheapest cartridge emulators, Debrix no more? (/showthread.php?tid=71349) |
Cheapest cartridge emulators, Debrix no more? - Nebuchernezzer - 19-01-15 What are the options for cartridge emulators for the old FZS these days? We put debrix emulators in the track bike but it appears they are no more? Can't get onto their website anymore so i'm assuming they are defunct. Is gold valves the only other option apart from that? Re: Cheapest cartridge emulators, Debrix no more? - darrsi - 19-01-15 Need to contact them to see if they have a pair. http://www.fazerspares.com/catalogue/126-1_suspension.htm Re: Cheapest cartridge emulators, Debrix no more? - kebab19 - 19-01-15 Darrsi, These are not standard fork parts, but an aftermarket mod on forks that I publicised last year: http://foc-u.co.uk/index.php?topic=8366.0 http://foc-u.co.uk/index.php/topic,9279.0.html So Fazer spares won't ever have them in stock. Nebuchernezzer: These babies appear to be the droids you're looking for - ebay item # 161561746981 But maybe only 1 set left? Get in quick! Not sure what's happened to the Debrix site, hopefully it's only down temporarily, otherwise Racetech or YSS emulators may be your only (expensive) options. EDIT: Another Stateside ebay seller here, but more expensive - # 191170530552 Re: Cheapest cartridge emulators, Debrix no more? - Nebuchernezzer - 19-01-15 Awesome thanks! The Debrix site has been down since i got my bike around 5 months ago , so sadly it seems to be an ongoing thing....Postage is a killer from the US isn't it! But still cheaper than racetech.... Re: Cheapest cartridge emulators, Debrix no more? - kebab19 - 19-01-15 Yes, the postage was always a killer, hence my Group buy of emulators to save $$$ back in 2013. You could also try putting a Wanted post on the SV650.org forum as the Suzuki bods seem a lot more keen on the emus, someone might still have a pair for sale. Re: Cheapest cartridge emulators, Debrix no more? - Nebuchernezzer - 20-01-15 I'm in Oz so i'm probably stuffed either way! But speaking of SV650 perhaps the SV650 people will be able to tell me the dimensions of standard SV650 fork springs. Saw some on gumtree and they are straight rate and from 41mm tubes....might be good in the fazer, but might also be not much of an upgrade at 0.7kg spring rate...$30 though so not bad. Re: Cheapest cartridge emulators, Debrix no more? - kebab19 - 20-01-15 Aftermarket SV650 springs would be an option, but as those bikes are some 20kg lighter than the FZS they'd need to be a fairly high spring rate. Aftermarket Bandit 600 ones (if available there) could be a better good choice as they're heavy old buses. For both my emu conversions I used standard springs from a 94-97 Honda VFR750 and then an early VFR800; although technically dual rate, from memory they averaged around 0.85kg which suited me fine. Re: Cheapest cartridge emulators, Debrix no more? - savvy - 20-01-15 have you thought about CBR springs? I used them and Thundercat fork tops adjustable but need a shorter spacer. See at the end of Kebab's topic as to how I did mine. Thanks again Kebab!! http://foc-u.co.uk/index.php/topic,9279.msg131635.html#msg131635 Re: Cheapest cartridge emulators, Debrix no more? - Nebuchernezzer - 20-01-15 It seems for my body weight i'd want about 0.8kg or a bit more roughly? I'm 68 kg without gear on. I have just bought a 2013 R6 rear shock as well. So get that with say a 650lb spring and i should be set. Oh yeah my mate sent me this link so i ordered my valves from here. http://www.motoparthub.com/24_0361_VTwin_41mm_Fork_Damper_Valve Re: Cheapest cartridge emulators, Debrix no more? - kebab19 - 21-01-15 According to this spring rate chart: http://www.mad-ducati.com/Technical/racetech/springchartstreet.gif You're about halfway between 0.80 and 0.85kg ... suppose it depends how comfortable you want things to be! You should indeed try 0.8 kg first as its kinda hard to stick bits of spring back on again :rollin Re: Cheapest cartridge emulators, Debrix no more? - Znd93rus - 21-01-15 Sorry for stupid question, but all links for emulators are for H.D. ones not for Fazer. is it correct? Re: Cheapest cartridge emulators, Debrix no more? - kebab19 - 21-01-15 Not a stupid question at all. A few years ago, some SV650 owners noticed these HD emulators suited 41mm diameter forks (and also noticed how cheap they were). They found that they were a straight for 1st Gen SV650 forks. In 2013 I discovered they were also perfect fit for Fazer FZS600 forks. The 'debate' about whether the Emulator's preload spring is too firm (to accommodate the extra weight of Harley Davidsons) is IMO a non-issue, as backing it's preload off makes it ideal for much lighter bikes such as Fazers Re: Cheapest cartridge emulators, Debrix no more? - Znd93rus - 21-01-15 (21-01-15, 04:24 PM)kebab19 link Wrote: Not a stupid question at all. Kebab19, that means that this emulators are great straight mod for Fazer? Have you or any forumriders tested it? I am thinking about suspention tuning. Maybe USD maybe EMU... need more information. But start from EMU looks less expensive and need less time to install. Re: Cheapest cartridge emulators, Debrix no more? - kebab19 - 21-01-15 They are the best modification you can do to the standard forks (if fitted alongside replacement springs). Obviously replacement cartridge forks swapped from other bikes would be even better. Yes, I first ran Racetech Emus in the forks back in 2008: http://foc-u.co.uk/index.php/topic,71.0.html And again with cheaper Debrix Emus when I bought my second Fazer 600: http://foc-u.co.uk/index.php/topic,8366.0.html And talked a few other forum members into a Group Buy: http://foc-u.co.uk/index.php/topic,9279.0.html Re: Cheapest cartridge emulators, Debrix no more? - Znd93rus - 22-01-15 (21-01-15, 11:27 PM)kebab19 link Wrote: They are the best modification you can do to the standard forks (if fitted alongside replacement springs). Obviously replacement cartridge forks swapped from other bikes would be even better. Kebab19, thank you for info. I found local springs manufactor with good prices and now plan to source for R6 shock and emu. Kebab, do you have any info about suitable for FZS600 catridge forks? And I can't find (I know and I saw your posts about it) which R6 shock good for and what parts I need for setup. Please give me link. |
