Are my wheel bearings knackered? (video) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Are my wheel bearings knackered? (video) (/showthread.php?tid=65320) |
Are my wheel bearings knackered? (video) - elbrownos - 02-09-13 So I thought I'd knackered my chain (see this thread http://foc-u.co.uk/index.php/topic,9648.0.html ) But I was advised to pop the chain off and see if it was the chain or the wheel bearings. I've posted two videos - one with the chain off and one with the chain on. Chain off: Wheel spinning - no chain I'm guessing it's not supposed to make that knocking noise? Chain on: Wheel spinning - with chain It doesn't spin nearly as long as it did a few weeks ago, which makes me suspect the chain. And the chain does sound really noisy. But I had a good feel of it and there were no tight links. I'm not sure what a new chain feels like so I can't tell if the whole chain is stiffer than it should be. Also in this video you can hear a high pitched squeal from the wheel when it's turning slowly. The bike's still riding fine and the weird noises at the rear have almost gone away. Any thoughts appreciated. Re: Are my wheel bearings knackered? (video) - Dead Eye - 02-09-13 Its definitely catching at the same point on every revolution - have you checked the disc to see if its catching on the pads. Same test but with the caliper removed would identify it - hard to hear where exactly the noise is coming from in the video. If its definitely on the left, how does the sprocket look in terms of alignment? Re: Are my wheel bearings knackered? (video) - AdieR - 03-09-13 On your top video (chain off), your sprocket looks like it's "wandering" from side to side to me, almost as if it's warped - how long have them chain / sprockets been on the bike? Have you had any work done recently eg new tyre / brakes? Check your wheel alignment / sprocket alignment, and a check of your cush drive rubbers is probably in order too. Re: Are my wheel bearings knackered? (video) - stevierst - 03-09-13 The sprocket carrier bearing could be knackered, mine went, and I only noticed when I took the wheel off to change the tyre. I spun the wheel without the chain on, and my sprocket was a bit 'wobbly', but the wheel was true. Might be worth a look. Re: Are my wheel bearings knackered? (video) - elbrownos - 03-09-13 Thanks guys I'm certain it's not related to the brake. Sprocket is perfectly straight as far as I can tell. I'm puzzled about why the knocking is only there when the chain is off. What are the usual signs of worn bearings? I can't detect any play moving the wheel side to side. I'm due for a new rear tyre soonish so I think I'll wait til the wheel's off and check everything out properly. |
