15w oil in front end - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 15w oil in front end (/showthread.php?tid=79406) |
Re: 15w oil in front end - Disorderlypunk - 24-03-18 Do you know when it was last changed? not a clue ive had it for a year and the bloke that had it before me didnt seem too clued up when it came to mechanical stuff so could be anything i should have changed the seals aswell but i forgot to order them and im planning a USD conversion anyhow so unless they start weeping oil im not to bothered for now Re: 15w oil in front end - fazersharp - 24-03-18 Ok so I admit I have not done a search on here but have looked at a utube vid for complete refurb which needs special tools and stuff. What is the most easy way of changing my oil, can it be don in situ. The thing is if I am taking them off and stripping down then while I am at it I will also be stripping the old lacquer off -buffing up - re lacquering blah blah, not to mention doing a"Harryhornby" and mullering something up, but all the time not having an issue with the handling in the first place. Do I really need to do it ? 20 year old bike - never seen rain-20k miles with a 9 1/2 stone racing snake on board. Re: 15w oil in front end - Disorderlypunk - 24-03-18 changing oil on its own is easy as anything as long as you have basic tools (socket set and allen keys) but a torque wrench is a good thing to have if you want to torque to spec (F-ing tight is the next best thing) only when it comes to oil seals do you need anything a bit more specialist but you can get away with ingenuity a drift and a broomstick handle (i prefer the screw in mop handles) a bench vice or black and decker workmate certainly makes life easier to clamp the stanchion while trying to get the top bolt back in but not essential if there is another set of hands available something to drain the oil into (why i always have a box of empty coffee jars) - if your mudguard has not been off in years be prepared for heartache though - the bolts often suffer from galvanic corrosion and will snap (£20 on front left) for some reason if it happens to me on a yam it is always front left, so take it easy use lots of plus gas/wd40/babyoil/ferrets urine whatever you use and wind it back and forth back and forth as you slowly remove the bolt - if it snaps then find someone who knows how to center drill and remove or helicoil (a good engineer will always try drill and remove first) a quick read of the manual should give you a good idea on where alternative tools can be used just dont trust it when it says to go to chapter one as it within 4 lines tells you to go back to chapter .......6? Re: 15w oil in front end - Disorderlypunk - 25-03-18 (23-03-18, 10:22 AM)mtread link Wrote: I'm with Slaninar, Scottoiler all the way. It includes a cleaning fluid and chains last 3+ times as long, that's proven. The container holds enough oil for at least 500 miles, so how can you forget to top it up? Would you forget to check tyre pressures? Better Scottoil than that sticky dirt magnet stuff that comes out of cans.500 miles - holy crap i would have to refill it every week at least i agree with matt entirely on this https://www.youtube.com/watch?v=T4xgcx6F6fw if you ride in all weathers they are not the best of ideas (although usefull to a degree) and as for 3x longer - in comparison to what ??? a properly looked after chain removing the road crap will last just as long as any scottoiler looked after chain, especially with o/x ring chains as we are no longer lubricating the inner rollers we are only lubricating the plates that hold the rollers together Re: 15w oil in front end - darrsi - 25-03-18 I don't use a Scottoiler, but tend to get the feeling when the chain needs a good scrub. Oiled or not, if you ride during winter the chain will pick up shite from the road, it's unavoidable. Just a case of common sense. I actually use WD40 as a cleaner with a brush, then Wurth chain lube afterwards. Done me alright for 30 years riding, so i'll stick with a proven method. Re: 15w oil in front end - tommyardin - 25-03-18 (24-03-18, 12:34 PM)darrsi link Wrote: [quote author=Disorderlypunk link=topic=23880.msg277184#msg277184 date=1521890699] Do you know when it was last changed? [/quote] Mine was dark, dark silvery grey and stank of fish, then there was the oil that came out of my forks :lol :lol :lol :rollin :rollin :rollin Re: 15w oil in front end - fazersharp - 25-03-18 (24-03-18, 10:31 PM)Disorderlypunk link Wrote: galvanic corrosionYou see that's all I need to read to put me off. I do have all the kit apart from the specialist tools. Judging by the sludge in there I wonder how much good a simple replace oil would do. Re: 15w oil in front end - Disorderlypunk - 25-03-18 the black in the bottom is not sludge its oil, the clear on the top is water that as made its way past the seals its definatly worth doing, the change in feel is more than noticable (but with that much water in its no suprise) over time the oil breaks down and should be replaced anyhow, its just no1 does Re: 15w oil in front end - darrsi - 25-03-18 (25-03-18, 10:50 AM)fazersharp link Wrote: [quote author=Disorderlypunk link=topic=23880.msg277215#msg277215 date=1521927106]You see that's all I need to read to put me off. I do have all the kit apart from the specialist tools. Judging by the sludge in there I wonder how much good a simple replace oil would do. [/quote] Why are you even contemplating the idea of changing 20 year old oil? Just do it......and use 15w. Then come back and tell everyone how you should've done it 20 years ago. :lol Re: 15w oil in front end - tommyardin - 25-03-18 (25-03-18, 10:50 AM)fazersharp link Wrote: [quote author=Disorderlypunk link=topic=23880.msg277215#msg277215 date=1521927106]You see that's all I need to read to put me off. I do have all the kit apart from the specialist tools. Judging by the sludge in there I wonder how much good a simple replace oil would do. [/quote] Ooyy! Sharpie, I hope you don't think like that about your engine oil. Re: 15w oil in front end - fazersharp - 25-03-18 (25-03-18, 02:43 PM)tommyardin link Wrote: [quote author=fazersharp link=topic=23880.msg277234#msg277234 date=1521971451]You see that's all I need to read to put me off. I do have all the kit apart from the specialist tools. Judging by the sludge in there I wonder how much good a simple replace oil would do. [/quote] Ooyy! Sharpie, I hope you don't think like that about your engine oil. [/quote] What I was meaning was if it is gunky sludge without actually dismantling and giving a proper clean I am putting clean oil into dirty tubes. Re: 15w oil in front end - Disorderlypunk - 25-03-18 it pretty much all comes out as long as you give them a few pump and leave them upside down for a bit 99% new oil is better than 0% new oil but yes a full dismantle would always be the best option when possible or absolutely required Re: 15w oil in front end - Slaninar - 26-03-18 (25-03-18, 01:42 AM)Disorderlypunk link Wrote: [quote author=mtread link=topic=23880.msg277146#msg277146 date=1521796928]500 miles - holy crap i would have to refill it every week at least i agree with matt entirely on this http://www.youtube.com/watch?v=T4xgcx6F6fw if you ride in all weathers they are not the best of ideas (although usefull to a degree) [size=1em]and as for 3x longer - in comparison to what ??? [/size] [size=1em]a properly looked after chain removing the road crap will last just as long as any scottoiler looked after chain, especially with o/x ring chains as we are no longer lubricating the inner rollers we are only lubricating the plates that hold the rollers together[/size] [/quote] My experience differs. The chain is very clean, without the need to clean it. And it is always lubed. Combination of dirt that gets stuck to a lubricant makes for a nice grinding paste - one of the reasons the chain lasts a lot shorter, than a lot thinner cam shaft chain, that is always closed inside the engine, always clean and lubed. Scottoiler keeps the chain lubed, while the ("thin") oil flings off it along with any dirt - so the chain stays both clean and lubed. Using other methods, it's very hard to clean the chain between the pins and the rollers, where it matters. Re: 15w oil in front end - reaper1064 - 13-04-18 Just done the 15w oil upgrade on mine, what a difference. Feels well planted now. Re: 15w oil in front end - Triggergee - 13-04-18 If anyone does want to go the full refurb route B&Q sell a 50mm waste pipe for a fiver or so that is a perfect fit to drive in the new oil seals. That and a broom handle is all the specialist tools you'll need Re: 15w oil in front end - mtread - 13-04-18 Quote:500 miles - holy crap i would have to refill it every week at leastOh well that's 20 seconds of your life you'll never get back then
