headlights.... leds,halogens,hids,projectors etc ect - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: headlights.... leds,halogens,hids,projectors etc ect (/showthread.php?tid=74171) |
Re: headlights.... leds,halogens,hids,projectors etc ect - mobile mouse - 06-11-15 Hi, Frosties pointed out that you should "remove the metal piece of shite in the dipped beam''. And you get Fucktons of extra light. Were is this piece of metal. I have a Foxeye Fazer do my headlights have the metal piece. I have fitted Philips bulbs, I cannot remember which version. And would like to maximise them. I have been looking at fitting additional relays and use heavy gauge cable to remove the volts drop from battery to bulb. Re: headlights.... leds,halogens,hids,projectors etc ect - sinto607276 - 06-11-15 What the foc are you saying mouse? Go on, let us know so we can help you :lol Re: headlights.... leds,halogens,hids,projectors etc ect - mobile mouse - 06-11-15 Has anyone tried fitting additional relays and use heavy gauge cable to remove the volts drop from battery to bulb. Does it work..... Re: headlights.... leds,halogens,hids,projectors etc ect - Paulfzs - 08-11-15 i had a spare 35w hid laying around... i dont have a spare one anymore ![]() 12v 7ah battery inside, flickers like mad for about 10 seconds then heats up enough and starts Re: headlights.... leds,halogens,hids,projectors etc ect - sinto607276 - 08-11-15 (08-11-15, 12:10 AM)Paulfzs link Wrote: i had a spare 35w hid laying around...I thought you were taking the mick till I zoomed in on the pic and saw you actually put a hole in the lamp ![]() So we now need pics of the actual light from it :lol Re: headlights.... leds,halogens,hids,projectors etc ect - Paulfzs - 08-11-15 Ill get on it its only 35w and a pretty crappy reflector but its got a decent beam on it i did however order a new 55w ballast so i can put it on my bike and switch it out with mine.its also shown me that my bike battery has to be enough to run a hid, the battery thats in it is a 12v 7ah one of these ![]() Not dark enough yet but the inside: ![]() ![]() Re: headlights.... leds,halogens,hids,projectors etc ect - hmmmnz - 08-11-15 ok here is the before shots of the very shite-ish lights on my fazer dipped beam ![]() and the not so mighty full beam ![]() taking off the metal reflector hasnt really helped things, but it hasnt made it a whole lot worse either. ill let you guys know how the projector lamps go when the turn up.i also bought a pair of led projectors to fit somewhere, 10watt each, so will be interesting how good they are for the minimal cost as well cheers hmmmnz Re: headlights.... leds,halogens,hids,projectors etc ect - sinto607276 - 08-11-15 (08-11-15, 02:21 PM)hmmmnz link Wrote: ok here is the before shots of the very shite-ish lights on my fazerThere nearly as good as Paul's HID'S :pokefun Seriously though..... Have you adjusted the beam direction? Yours seem to be a bit low. Re: headlights.... leds,halogens,hids,projectors etc ect - Paulfzs - 08-11-15 (08-11-15, 02:31 PM)sinto link Wrote: [quote author=hmmmnz link=topic=18605.msg215438#msg215438 date=1446988887]There nearly as good as Paul's HID'S :pokefun [/quote] This is so true! i cant seriously keep getting bad batches of bulbs and ballasts! new bulbs and ballast last week just as bad Re: headlights.... leds,halogens,hids,projectors etc ect - sinto607276 - 08-11-15 (08-11-15, 02:50 PM)Paulfzs link Wrote: [quote author=sinto link=topic=18605.msg215440#msg215440 date=1446989510]There nearly as good as Paul's HID'S :pokefun [/quote] This is so true! i cant seriously keep getting bad batches of bulbs and ballasts! new bulbs and ballast last week just as bad [/quote] I don't what your doing :pokefun Could possibly be your regulator/rectifier isn't up to it? Re: headlights.... leds,halogens,hids,projectors etc ect - Paulfzs - 09-11-15 Even straight from the battery its weak, i will have to remove the battery and wire the 22ah one and see what happens Re: headlights.... leds,halogens,hids,projectors etc ect - Doggy - 09-11-15 I had the same problem with my 96 TDM850. HIDS4U supplied a complete kit for the dip beam which was a 20 minute job to fit and made a huge difference. I did not fit a HID kit to the main beam as there is a slight delay in getting full power from the lamps, instead went for a night breaker bulb which made a bit of difference but lasted 20 miles! Hope this helps Doggy Re: headlights.... leds,halogens,hids,projectors etc ect - hmmmnz - 23-11-15 well the lights turned up over the weekend. bit of a mission to get all installed and hide all the wiring, 2 sets of ballasts, 2 relay boxes, 2 hi/low beam cables, 2 "angel eye" voltage boxes etc etc, plus wiring to run back to the battery. not hard but time consuming. pretty damn good results though angle eyes..... (aka park/pilot light) ![]() dipped beam ![]() full beam ![]() i think my low beam is a bit high, but we'll see how many times i get flashed in the next few days light is a bit white and it takes a minute or so to fully warm up but its like night and day though, amazing that 35watts can throw out so much light Re: headlights.... leds,halogens,hids,projectors etc ect - sinto607276 - 23-11-15 Looks good ![]() Where did you get that setup from? Re: headlights.... leds,halogens,hids,projectors etc ect - hmmmnz - 23-11-15 I bought it off aliexpress http://www.aliexpress.com/item/2ABC-Universal-Motorbike-35w-2-inch-Hid-Bi-xenon-Projector-Lens-Kit-wiht-Slim-Ballast-Blue/865239432.html All in including DHL postage was under £60 Re: headlights.... leds,halogens,hids,projectors etc ect - sinto607276 - 24-11-15 (23-11-15, 09:41 AM)hmmmnz link Wrote: I bought it off aliexpress http://www.aliexpress.com/item/2ABC-Universal-Motorbike-35w-2-inch-Hid-Bi-xenon-Projector-Lens-Kit-wiht-Slim-Ballast-Blue/865239432.html That link is just for one? How did you fit them? Did you have to split the headlight unit etc? Re: headlights.... leds,halogens,hids,projectors etc ect - markus2066 - 24-11-15 Not sure if anyone has mentioned these they were installed on my bike when I brought it 3 months ago, I've always been seriously impressed with them (not the cheapest option). https://www.retrofitlab.com/yamaha-fzs600-mh1-1.html Re: headlights.... leds,halogens,hids,projectors etc ect - Nebuchernezzer - 25-11-15 How do the projectors go mounting? Looks like some of them use a h4 shaped back end to just hold the projector. Does it work ok? Seems like it's be a bit wobbly to me. Re: headlights.... leds,halogens,hids,projectors etc ect - Paulfzs - 25-11-15 (24-11-15, 11:40 AM)sinto link Wrote: [quote author=hmmmnz link=topic=18605.msg216956#msg216956 date=1448268089] How did you fit them? Did you have to split the headlight unit etc? [/quote] I also want to know this! but they do look like this soo... this looks good to me! However the h1 hole is a lot smaller than the h4? maybe op can comment ! No longer available Re: headlights.... leds,halogens,hids,projectors etc ect - hmmmnz - 25-11-15 Yeah the link is just for one set. So if you do both sides you'll need to buy 2 sets. I followed instructions herehttp://fotifixes.com/2012/12/27/hid-projector-installation-in-a-2001-fazer-600/ Yeah you have to split the lights. 5 mins I'm the oven at 90'C softened everything up nicely. Same to put it back together Carved out the h1 hole to fit the h4 projector. We'll worth the effort. You could just to 1 projector if you didn't want to wreck your light. But In my eyes it was no great loss. |
