100 nm without a torque wrench - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: 100 nm without a torque wrench (/showthread.php?tid=73364) Pages:
Re: 100 nm without a torque wrench - lew600fazer - 30-07-15 (30-07-15, 11:51 AM)J_Dub link Wrote: 100 Nm is correct, (boxeye is 60Nm) for the sprocket. Buy a torque wrench you need one to tighten the spindle too! Re: 100 nm without a torque wrench - JoeRock - 30-07-15 (30-07-15, 11:47 AM)Grahamm link Wrote: [quote author=chaz link=topic=17798.msg205502#msg205502 date=1438249818] That's exactly what it says in the Haynes Manual: Rear sprocket nuts: 100 Nm Rear wheel axle nut: 120 Nm I'm going to use Threadlock as well anyway. [/quote] Personally I wouldn't bother - get them torqued up properly and you shouldn't need it (pretty sure they're meant to be dry threads on those nuts according to the Yam manual?) Re: 100 nm without a torque wrench - chaz - 30-07-15 well I better get me nuts tightened? How can you torque them up dry and have thread lock on? I've never used thread lock as a lube but it must have some effect on it. Re: 100 nm without a torque wrench - lew600fazer - 30-07-15 As someone else mentioned are they not nylock nuts anyway?? For me the only bolts , nuts , studs I would likely use a torque wrench on would be , bottom ends, main bearings and cylinder head nuts, coming from an engineering background I would think I am reasonably confident to not over torque or under torque fastenings. Re: 100 nm without a torque wrench - VNA - 30-07-15 If you have torque wrenches it makes sense to use them. Can't remember what the torque for my rear axle nut is, but considering I like to be able to get it back off I tend to torque it a good wee bit short. I'm not keen on cheap torque wrenches. Somebody mentioned Norbar. I recently bought a Norbar, very nice, comes with a calibration certificate. Not cheap but will last the home mechanic a life time. Also got a Britool which is nice too. Did buy a cheap (ish) Williams wrench a while back. Used it a couple of times but I'd no confidence in it. Replaced with the Norbar. Re: 100 nm without a torque wrench - Grahamm - 30-07-15 The nuts on the sprocker are, indeed, nylocs, so I didn't bother with the Threadlock too. Re: 100 nm without a torque wrench - fazerscotty - 30-07-15 This is "Sprocket" and he doesn't like his nuts torqued at all :rollin :rollin :rollin :rollin Re: 100 nm without a torque wrench - fazerscotty - 30-07-15 And as for "Bear" - any takers? :lol :lol :lol Re: 100 nm without a torque wrench - lew600fazer - 30-07-15 (30-07-15, 07:47 PM)VNA link Wrote: If you have torque wrenches it makes sense to use them.A torque wrench is only as good as the last time it was calibrated which should be Annually. Re: 100 nm without a torque wrench - lew600fazer - 30-07-15 (30-07-15, 08:59 PM)fazerscotty link Wrote: And as for "Bear" - any takers? :lol :lol :lolCouple of whores the pair of them lol. Look as if they have been out on the tiles lol
Re: 100 nm without a torque wrench - Dave48 - 31-07-15 "Lie back & think of England" or should i be guided by your username & say "Scotland" ? :lol Re: 100 nm without a torque wrench - fazerscotty - 31-07-15 (30-07-15, 10:44 PM)lew600fazer link Wrote: [quote author=fazerscotty link=topic=17798.msg205568#msg205568 date=1438286363]Couple of whores the pair of them lol. Look as if they have been out on the tiles lol [/quote] No this is what happens when they hit the water bowl............ Re: 100 nm without a torque wrench - lew600fazer - 31-07-15 Who would have kids eh!!! these two are the dogs!!!! keep sharing what they get up to, love it. Lew Re: 100 nm without a torque wrench - VNA - 02-08-15 Quote:A torque wrench is only as good as the last time it was calibrated which should be Annually. All depends on what you are doing. I doubt I'll ever calibrate mine. It's not gonna get that much use. It will be religiously wound back to zero when it is not in use. In short buy a good one, treat it with respect, look after it and it'll last you a life time. On the other hand at my work annual calibrations are not acceptable. We don't use wrenches with scale markings, only a range mark. Each wrench is set before and after use on a torque wrench analyser. It's the torque wrench analysers that get calibrated every year. Re: 100 nm without a torque wrench - lew600fazer - 02-08-15 Well in my work they were calibrated annually as specified by the classification society. Re: 100 nm without a torque wrench - Freck - 02-08-15 You're right that torque wrenches should be calibrated regularly, but more importantly they should be checked each time they are set. I work in the aviation industry and when using a torque wrench we are required to check the set torque on a calibrated gauge before use, and whenever it is adjusted to a new setting. I know this is a little over the top for a home mechanic but it is the only way of ensuring the correct torque is applied. Most people don't know how to use a torque wrench correctly anyway, that's if they use one at all :rolleyes Re: 100 nm without a torque wrench - fazerscotty - 02-08-15 I still say two white knuckles or three..... Re: 100 nm without a torque wrench - lew600fazer - 02-08-15 (02-08-15, 08:58 PM)fazerscotty link Wrote: I still say two white knuckles or three..... |
