neutral light?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: neutral light?? (/showthread.php?tid=58669) Pages:
Re: neutral light?? - bikemad62 - 17-05-12 Try the multi relay in the side panel. It controls the starting and the fuel pump inc neutral light borrow another relay clean the plug, plug in the loan relay. if the problem goes buy a new relay. Hope this helps. Re: neutral light?? - CRH - 17-05-12 first of all thanks for your input bikermad!!.......BUT ....cracked the fkd up, never t cum down agen bstd!!!!!!!!! first of all i followed clayt and andys ideas! took off side panel ,removed relays, pulled out connectors, made sure they was ok?, then traced wiring bk to under tank and tooked away under coil bracket is the diode!!removed that and chkd for continuity! that was ok?..so next step was to disconnect live feed to neutral light!!(green plug)... n guess what??...fkn light still on :'( ..so i thought ? right!,something not fkn right here???...i then disconnected the blue plug!!..and the bstd went out when i selected gear :\ ..so? me thinks the blue plug feeds the side stand switch!! the fault MUST BE IN THE WIRING???..feeding the neutral light?(dont ask me how) anyway? after examining the wire!.. i found the :evil little bstd!!!where the wire is routed down from top of engine it passes through the waterpump and somehow had worn through!! it had fused itself to the water pump (out of view) body!! so ive simply chopped the wire and put a new piece in! and ...eureka.. :rollin its bang tidy agen!!anyway thanks to everybody who helped sort it for me!! and if i was use!! i would give yours a quick check over? and where it touches the water pipe give it some good insulation, it may be just a one off but worth checking ?? thanks again clive ..
Re: neutral light?? - red98 - 17-05-12 well done crh ....another fazer back on the road...
