Date: 02-05-26  Time: 20:42 pm
Author Topic: easily accessed switched live on a fz1?  (Read 4889 times)
ogri48
« on: 17 September 2013, 10:00:28 am »
ive gotta put a coupla relays in for heated gear, i'll check out the loom with me multimeter, but is there an easily accessed and fairly thick wire anybodies already found to connect into?
atb
paul
Aegis Bearing Mel
Re: easily accessed switched live on a fz1?
« Reply #1 on: 17 September 2013, 02:24:19 pm »
I connected straight to the battery but used the rear brake switch as the trigger circuit for the relay.
I'll take a couple of photies when I'm home if you want.
ogri48
« Reply #2 on: 17 September 2013, 04:13:40 pm »
Thanks mel that sounds pukka mate :)
slimwilly
« Reply #3 on: 17 September 2013, 06:24:30 pm »
Yes,while you have the tank up go back to the battery, though i reckon you should put one wire out from the battery and then split that as you will end
 up with four or more stacked on the battery terminal.
VNA - BMW Wank
« Reply #4 on: 17 September 2013, 09:04:06 pm »
What you want is the switched live from the fuse box.
Now mines a Gen1 but chances are the fuse box is the same or similar.
If it is, it's just a matter of popping one of the switched lives out and soldering on to the spare tab.
The trick is locating the little tabs that hold the live tab or conductor in.
All the photos were on the old forum, but that cannae be accessed any more.
See if I can get the photos in here;
Pop the fuses out (noting where they all go!)
Now look for the plastic clips;
Ease the clip back (an instrument or jeweller's screwer driver should be ideal) and push one of the switched lives out.
Solder on your live feed, remembering to fit an inline fuse (you want it as near to the fuse box as poss)
Bob's yer Uncle;
Hope that is of some help.
ogri48
« Reply #5 on: 18 September 2013, 08:12:23 am »
Thanks mate  :) :)
PaulSmith
« Reply #6 on: 20 September 2013, 12:05:27 pm »
