Date: 21-04-26  Time: 06:09 am
Author Topic: Blackberry play book  (Read 3327 times)
snapper
« on: 07 September 2013, 05:58:42 pm »
Help before I throw this focking thing on the floor and dance on it !
 at home I have sky wifi
My mrs has bt wifi
and she has work wifi that is optical infinaty
people around us has bt and we are in a bt open zone
every fecking time I try to use the play book it logs into open zone which to say is sh!t is an understament
try to change it back but as soon as i come of the wifi set up window it logs out and back into fecking bt openreach/zone what ever the feck it is
 I cant use it anymore because of the level of frustration i have with it !
help PPPPPLLLLLEEEEase !
Chillum
Re: Blackberry play book
« Reply #1 on: 07 September 2013, 06:22:26 pm »
Is your blackberry configured with the open zone login details then?
Gary
« Reply #2 on: 07 September 2013, 06:25:18 pm »
Seems to be a common issue with BT as they take higher priority for connections than other services. Im not familiar with the play book but go to your wifi settings and see if theres anything that can be done to set your Sky as default / disable connection to BT?? Hope this helps somewhat . Gary
snapper
« Reply #3 on: 07 September 2013, 07:02:24 pm »
Hunted high and low looking for a way to block bt but I canrt find anything !
 I cant find a way to set my sky as default !
I dont think you need to set up for bt open zone its free ! I think !
thanks for the advise keep trying please
ChristoT
« Reply #4 on: 07 September 2013, 07:44:51 pm »
On most devices, you are able to tell the device to "forget" the BT access points, and maybe even manually rearrange its priority list. Never used a Playbook or a Blackberry even, but there should be some way of finding something like that squirrelled away in a settings submenu.  :)
snapper
« Reply #5 on: 07 September 2013, 08:09:04 pm »
found a "problem network " tab will see how i get on
cheers  people
Chillum
« Reply #6 on: 07 September 2013, 10:07:38 pm »
on my blackberry under the 'manage wifi' settings I can configure the wi-fi networks I want to connect to. I'm pretty sure that to connect to a wi-fi (even a BT openzone job) you need to have the SSID configured in this area at least - see if it's there and if it is, delete it.
